I started to build my own fur solution some time ago in Ice. So far, so good. But when I started rendering in mr, I pretty soon began to realize that transparency settings resulted in very ugly artefacts along the Ice strands.
In modo I'm used to get this stuff with transparency, as Modo uses cylinders as hair segments. On their borders they overlap and produce a darker section as the ray needs to pass two volumes at once.
I tried several hair shaders, but being a stranger to mr I can't tell what's wrong. Blobs for strands don't look like a solution to me, as the amount of hair is too much.
Is vray a solution or is there a checkbox somewhere that a ray can't enter two volumes in a row, before it left one? This way intersections shouldn't be a problem.
Cheers Thomas
