Having decided not to jump on the very tempting Houdini Indie bandwagon, mostly because I dread the necessary “learning curve” involved, I came to the conclusion I should invest my money in a Redshift license. But before I do I still have some questions. The current demo version of the software is 1.3.35 (or 1.3.37?) and the two limitations I have found are that there are no toon shaders and Redshift doesn't seem to support volume shaders. I understand I do not have to start holding my breath for toon shaders in Redshift, but volume shaders would be most welcome. Are these part of version 2 of the renderer? And how far along is the development of version 2? Will a stable version be released any time soon?
And finally: what else is “missing” from Redshift that I might have overlooked?
Redshift - pre-purchase questions
Re: Redshift - pre-purchase questions
My 2 cents...
A toon shader can be done with a simple gradient plugged in an incidence shader ;-)
Or better, done by using a full reflection image map (you know the mirror balls) like the matcap_058 here http://www.si-community.com/community/v ... 9&start=10 the wonder of this is that's displaying in your softimage HiQuality viewport ;-)
There's absolutly no reason to not jump in
I still use the mental ray toon shader - yes you can fake some stuff in RS but its much easier to revert back to MR just for the jobs that require toon stuff.
They're making a lot of progress with volumes in RS but it will still take a while to get to the level of flexibility/functionality that MR had (albeit with custom shaders from Holger). I think we'll see more once people are able to write custom shaders/have access to an API.
Lastly I do miss the range of procedural shaders that were available for MR. Not as much as I thought, but for noise in AO etc it would come in handy to have more options for RS.
Redshift Volume rendering is supported on Houdini why it's not in Softimage ??
ok Volume is a 2.0 feature that's whyNNois wrote:Redshift Volume rendering is supported on Houdini why it's not in Softimage ??
