interactive car rig
interactive car rig
Ok,
I'm trying to make an interactive car rig to learn a bit more rig/simulation, and I have two problems :
firstable, when I use a fixed constraint between two simple cubes, all is fine with default settings, but when I apply the same thing between the four little cubes you can see in the video, and the big one in the center, all is shivering... The only thing I found to solve it is to raise to 100 the substeps number in the physx dynamic operator. Is it normal ?
My second probem : I applied a hinge constaint between my wheels and my little cubes. The behavior of the wheels seems ok, but hinges are rolling all the time....
What's the problem ?
here is a little video to show you concretely :
thanks for your advices.
PS : thanks to moderator for editing the video ID
Re: interactive car rig
Ok,
I experimented a bit more, and it seems that shakes appears only when there is a significant difference between the respective sizes of the objects.
If volumes are approximately the same, there is no problem anymore...
any idea please ?
any idea please ?
Ok, so it seems that simulation specialists are not on si-community ;)
I try a last question as I didn't succeed on driving a specific rotation axis of an active rigid body. Is it possible ?
- xsisupport
Did you see this article on andynicholas.com ? Building A Car Rig
Thank you, I've seen it, but my goal is to build a rig able to do things like that :
That's not the case of the Nicholas's one.
What are you using for your RBDs simulation ?
I'm making a falling car (a simple one) kind of "ragdoll" with Momentum and it's working good enough atm.
I'm using native RBDs simulation tools, not ICE.
Did you manage to get somehing working ?
No, I didn't find any solution to constraint the simulated wheels orientation during the simulation.
Maybe ICE is the solution, but I'm a total beginner with it.
