I just downloaded and installed 3.12. As there is no .addon file included I just put the directory into my workgroup. The menu is showing up in my to bar, but neither my own scene nor the examples which come with 3.12 work correctly/at all.
As the update is from November I can't believe that nobody else discovered these problems. Only Jamination mentioned the same problems on the mailing list, but no answer from Exocortex. Anybody else with the same problem or a solution?
Thomas
Is Momentum 3.12 working for anybody at all?
Re: Is Momentum 3.12 working for anybody at all?
I went back to 3.10. This seems to work, but I need to "Force (a) Scene Reset". Otherwise the instances in my scene wouldn't get simulated.
Nobody with 3.12 running?
Just waiting on the next release, v4, to re-install and get to grips with again.
Do you know how it will be improved?
I only read that implosia will be part of it.
Hi Matt, waiting here, too. Hope it won't take so much longer.
