quickinset
QuickInset
Updated May 2013 (info) — Rewrite of the original QuickExtrude tool. This tool performs quick modo-like
interactive extrude, bevel and inset operations without showing a property page. Piotrek's
notes from the si-community thread: Extruding along normal is available only in 2012 SAP
for operations that relies on SI units you drag in component's normal direction,
for other ops (like point skirting ratio/bevel subdivisions) just drag across screen
subdivision highlighting is supported only for level 1 and only catmull-clark
J, L hotkeys change subdivision on extrude K hotkey is for repeating operation on highlighted component/subselection ENTER shows op PPG shift makes operations 10x slower
LMB is extruding, LMB and then RMB - changes inset ratio of extrusion MMB is beveling, , MMB and then RMB - changes bevel subdivisions RMB is insetting tool can also work in supra mode if you hotkey the tool
I've used it to model few production objects and it's pretty useful.
Re: quickinset
Sorry for the name of the cable in the message. I tried to compile an empty project. Same error with quickExtrude
Re: quickinset
If this happens for simple Hello world project too, it's an issue with the Visual Studio installation. In that case I would try reinstalling VS (maybe upgrade to community version 2017)
Re: quickinset
TRACKER : error TRK0005: Failed to locate: "CL.exe". The system cannot find the file specified.
I only get this message when I run visual studio using the bat file.
Maybe someone knows how to overcome this error? I am using Visual studio 2012.
Re: quickinset
This is an error when compiling a project.
Re: quickinset
Which bat file do you mean? Can you post it? It might change some path to point VS to the wrong CL.exe
Re: quickinset
I created a bat file to run as described on the site. http://docs.autodesk.com/SI/2015/ENU/So ... lugins.htm
@echo off
call "C:\Program Files\Autodesk\Softimage 2015\Application\bin\Setenv.bat"
call "C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\vcvarsall.bat" amd64
set PATH
set "XSISDK_ROOT=C:\Program Files\Autodesk\Softimage 2015\XSISDK"
"C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\IDE\WDExpress.exe" /useenv
echo on
I apologize in advance, I guess I'm doing everything wrong. Is it possible for someone to compile this plugin with my custom hotkeys? Or tell how to do it correctly.
@echo off
set PATH
echo on
Re: quickinset
I found a mistake. And everything started to compile. Sorry for the trouble.
Re: quickinset
no worries! what had been the issue?
Re: quickinset
In the bat file you need to delete / useenv. This solved the problem and the program was compiled.
Like this
Like this
Users browsing this forum: No registered users and 14 guests
