LivePaint plugin
LivePaint
Here is an alpha version of a paint tool that doesn't need weight maps to deform a
mesh. It's far from finished but is usable for painting push and smoothing. To install,
copy the dll in your plugin directory then run this jscript command in the script
editor: LivePaint()
Some things you need to know: only 32bit for now RMB to chose between push and smooth shift drag to change the brushopacity control drag to change the brush radius it only work on freezed objects undo will revert the object to it's state befor freeze there are many bugs, use it at your own risk — Have fun.
local backup: LivePaint.32.dll LivePaint.64.dll (copy to a Plugins directory)
Re: LivePaint plugin
Hi Jester
Thanks for the feedback, I know about this crash, it occurs undoing while the tool is still active.
Undo is not that easy to get as the putPositionArray function is quite limited (I think it's for performance reasons)
so I have to find a workarounds.
All tour requests are already on my list, be patient ;)
Ahmidou
Ahmidou
gr8! wait for stability version and undo function
Ok I can see the circle representing radius. But cant Adjust it R doesnt work.
The colors of the verts highlight but I dont see any deformation.
Some explanation of how the tools works perhaps I'm doing something wrong.
Oh and in 2012 SP1 x64 on exit I get:
' ERROR : 2268 - This function is missing:
' <function: LivePaint_DoExitTool>
' <path: \\3DM-SPACEDOCK\XSI_workgroups\3Dmotif_2012\Application\Plugins\LivePaint.64.dll>
calmasacow wrote:Ok I can see the circle representing radius. But cant Adjust it R doesnt work.
Ahmidou said there are some things you need to know:
-RMB to chose between push and smooth
-shift drag to change the brushopacity
-control drag to change the brush radius
-it only work on freezed objects
-undo will revert the object to it's state befor freeze
-there are many bugs, use it at your own risk
I forgot to say that the exit is not implemented yet, and the brush opacity/size update
is not working fine yet (but it's working).
I think I have found something for the undo and the crash.
A new version will come soon.
Regards
A.
Regards
A.
camer wrote:not work ( softimage 2012 sp1 x32)
win7 x64 si2012 sp1
the same problem . ..
You may miss some libraries can you test the dll with this utility: http://www.dependencywalker.com/anyheart wrote:
win7 x64 si2012 sp1
- Hirazi Blue
What did you compile it with?
Could be simply some users are missing the necessary runtime redistributables,
which especially make sense, if you used the 2010 version of Microsofts compiler,
as not everyone has them yet...
If so: here are the runtimes: x86 and x64
Ahmidou wrote:You may miss some libraries can you test the dll with this utility: http://www.dependencywalker.com/anyheart wrote:
win7 x64 si2012 sp1
errors were detected when processing
"c:\users\cgs\autodesk\softimage_2012_sp1\application\plugins\LIVEPAINT.64.DLL."See the log window for details.
here is the details:
Error: At least one required implicit or forwarded dependency was not found.
Warning: At least one delay-load dependency module was not found.
Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
- Attachments
- 001a.jpg (48.34 KiB) Viewed 5326 times
i try it(Microsoft Visual C++ 2010 Redistributable Package (x86)) in xp32, but still the same problem...
I'm sorry this is not working for you.
SICPPSDK are softimage libs, so you should have them linked and
I used MVS 2010 express so the redistributable package should work
You ca try to find the dlls on the web and copy them in the same diretory you copyed the plugin, but I think that's a bad solution.
Anyway I'm still fighting to make the undo work I have a solution with user data map but it's slowing fps down a lot....
Regards
Regards
- Hirazi Blue
That is indeed a very bad solution as there is way too much malware around disguised as "genuine dll's".Ahmidou wrote:You ca try to find the dlls on the web and copy them in the same diretory you copyed the plugin, but I think that's a bad solution.
From what I can tell from a quick internet search, I get the vague impression, Visual C++ 2010 might not be completely compatible with XP anymore, as there are several reports of missing dlls related to XP & the 2010 redistributable.
That said, one question seems to remain, @anyheart: your Windows XP installation has been updated to include Service Pack 3? I don't know if that matters much, but it seems to be a requirement for the redistributable.
Hirazi Blue wrote:That is indeed a very bad solution as there is way too much malware around disguised as "genuine dll's".Ahmidou wrote:You ca try to find the dlls on the web and copy them in the same diretory you copyed the plugin, but I think that's a bad solution.
yes,it is Service Pack 3.
- Hirazi Blue
You could try download the demo of Dependency Checker and try it on the dll. This software seems to give a more straight-forward account of the dependencies and even tells you which are obviously missing. After that we might get a clearer picture of what's going on. Don't know if this helps, but you can always try.
edit: but looking at your earlier screenshot again, couldn't it just be, you're trying to install the x64 version of the plugin, "LivePaint.64.dll" on a 32 bit machine, for which you should use the 32 bit version, "LivePaint.32.dll"?
i use the “LivePaint.64.dll” on win7 x64 , and use the "LivePaint.32.dll" on xp_sp3 32bit....Hirazi Blue wrote:You could try download the demo of Dependency Checker and try it on the dll. This software seems to give a more straight-forward account of the dependencies and even tells you which are obviously missing. After that we might get a clearer picture of what's going on. Don't know if this helps, but you can always try.
- Hirazi Blue
Okay, my mistake. I didn't understand why you mention them both. Now I do. ;)
Users browsing this forum: No registered users and 24 guests
