Thanks Ahmidou. This tool is a massive bonus. Any plans to pick this up again?
Painting indents on holding something like alt would be super awesome....our own little zbrush in Softimage.
LivePaint plugin
LivePaint
Here is an alpha version of a paint tool that doesn't need weight maps to deform a
mesh. It's far from finished but is usable for painting push and smoothing. To install,
copy the dll in your plugin directory then run this jscript command in the script
editor: LivePaint()
Some things you need to know: only 32bit for now RMB to chose between push and smooth shift drag to change the brushopacity control drag to change the brush radius it only work on freezed objects undo will revert the object to it's state befor freeze there are many bugs, use it at your own risk — Have fun.
local backup: LivePaint.32.dll LivePaint.64.dll (copy to a Plugins directory)
- Skype: nguyenvuducthuy
Re: LivePaint plugin
i hope he will pick up and implement more, i dream about texture painting in softimage
I'd be happy to pay for this if the author would finish it. I'm sure everyone would chip in from here? Would love to see 2-3 more brushes added to it!
I haven't came here in ages, but it's good to see there a re still active and people are active.
I may try to do a some updates, but it's hard do find some time, soit's going to be sparse and I can't give an ETA.
should set up a Gumroad or something?
- wireframex
Hey Ahmidou
Gumroad will be a very good idea
Yes, basic push pull brush, save my life several times already!
Users browsing this forum: brandwatch [Bot] and 37 guests
