I have this plugin that is essentially just a bunch of external scripts and a handy toolbar to execute them. No idea where ive got it from, but i have added some of my own scripts to it and some other i have collected over time.
So i figured i can easily migrate this plugin by simply copying the folder from the the user preferences. However, if i try making .xsiaddon (plugin manager>package addon) this doesnt work. When i install the addon i have created, all the buttons in the toolbar are greyed out. I think it doesnt register custom commands so the buttons execute non-existing ones.
Im totally confused by this, to be honest. I thought when you pack the addon via a plugin manager, it collects all the necessary data but this doesnt seem to be the case.
Packing a toolbar into a plugin
Re: Packing a toolbar into a plugin
Just guessing, but when copying the scripts ("copying the folder from the the user preferences"), did you remove the originals? If not, it could be that Softimage is trying in vain to register the commands twice (you should be able to see this in the "History pane")...
- xsisupport
Do the disabled (grayed out) toolbar buttons also say "(Missing)" ?
What exactly did you copy from your Softimage User folder?
And where did you copy it to?
Did you create a new Addon in the Plugin Manager, and copy stuff there?
And are you installing this addon on a different machine?
- bottleofram
Steve, yes it says "(Missing)", but i was wrong when i said copying the folder (from user/autodesk/softimage/addons) keeps everything working. It doesnt.
What i did was:
select code>drag and drop into the toolbar>create button (external script)>save toolbar
This effectively creates the custom command, but its a one-off thing. If you were to try and pack this into an addon and than install it on a different machine, it wouldn't work because the command creation process is skipped.
So, obviously, i just dont know enough about how this things work and how to create a self installing command/button. Im sure its explained somewhere in the docs, so no worries, ill figure it out when i have time to read through. Thanks anyway.
Oh, your python version of AddPointToNull script doesnt work in 2013 (change in "import si" etc). Thought you might wanna know.
What i did was:
- xsisupport
This may help.bottleofram wrote:Steve, yes it says "(Missing)", but i was wrong when i said copying the folder (from user/autodesk/softimage/addons) keeps everything working. It doesnt.
What i did was:
http://xsisupport.wordpress.com/2012/04 ... to-addons/
- bottleofram
Most definitely does. I've seen commandmap files and suspected they might be the problem, but had no idea how to pack everything together.xsisupport wrote:This may help.
This clears it. Thank you!
