Soft Transform
Soft Transform
AKA its full name Screen Space Proportional Object Transform. This tool works similar to the built-in Proportional Transform Tool, but operates on objects instead of on points. Features as listed in the si-community
thread:
TAB switches modes translate/rotate/scale (like in tweak tool) l/m/r mouse button for t/r/s (like in view space transform tool) .Rot. and scale is temporary, after releasing m/r button, tool switches to translate mode fcurve falloff from Move Proportional tool R hotkey for size change (like tweak tool) auto key handling for animation distance is measured to object's pivot point lock transformation to selected objects fancy buttons basic collisions (raw triangle mesh vs swept bounding sphere)
video demo / video demo (updated version) . Source available here. More details inside the si-community thread.
local backup: SoftTransform_x64_v11.xsiaddon
Re: Soft Transform
thanks for the source code! But I see you used the Windows SDK 7.1, I have tried to Setup it on my computer but I could not, and it appears to me the following message :
""A problem occurred while installing selected Windows SDK components.
Installation of the “Microsoft Windows SDK for Windows 7″ product has reported the following error: Please refer to Samples\Setup\HTML\ConfigDetails.htm document for further information.
Please attempt to resolve the problem and then start Windows SDK setup again. If you continue to have problems with this issue, please visit the SDK team support page at http://go.microsoft.com/fwlink/?LinkId=130245.
Click the View Log button to review the installation log.
To exit, click Finish. ""
Have you experienced this problem? , Analyzed, and how?
Please note that the computerized system is 64-bit.
Thanx
Thanx
Re: Soft Transform
Sorry I don't know what that means.
AFAIK If you own full visual studio (not express) you can compile without 7.1 sdk.
One thing I learned that installing service pack 1 will break VS.
There is also microsoft tool for cleaning your windows from visual studio/net stuff, so you can start over with clean installation
Re: Soft Transform
hi
There is a small problem in this plugin
If the Objects within the tree, the plugin is not able to put the keyframes of the Objects when moving
thanx
thanx
Re: Soft Transform
Hi, I fixed this bug and added falloff bias to the brush (like tweak tool, shift+r). Updated first post with new version.mjd3d wrote:hi
thanx
Re: Soft Transform
thank you !origin wrote:keyboard mapping->custom script commands
Oops ,something went wrong
Re: Soft Transform
Origin ! Please !!!! do so this tool could work with animation layers, or shapes manage! PLease ! and if possible to do so work with clusters point ! Thank you very much ! you good Man !origin wrote:keyboard mapping->custom script commands
Re: Soft Transform
wow, great plugin ! Thanks a big bunch for sharing this little gem !
Users browsing this forum: Bing [Bot] and 25 guests
