SoftimageGarage|HairDew1.0
HairDew
V1.0 released Feb 20th 2019 — From the si-community thread:
HairDew provides a very quick & easy workflow for animating long (or short) hair,
from start to finish. It includesa Hair shader compound (Redshift) with volume scattering, illumination parameter isolation,
and textured variation visualization,
ICE nodes for both Sim & Styling based on Kinstinka, Melena, GroomTools, (+ some of
my own nodes) and StrandCollisionFramework
means to easily setup everything,
many (old and recently added) features! There is also a more or less similar MentalRay
shader compound that could be re-emplemented with a bit of work. (currenly not included)
HairDew is a workflow-in-a-box like solution rather than a plugin, so make sure to visit the thread below and follow the video tutorial to get an overview.
local backup: HairDew-project.zip HairDew-required-addons.zip
Greetz!
Introducing HairDew!
___________________________________________________________________________
HairDew provides a very quick & easy workflow for animating long (or short) hair, from start to finish.
It includes - a Hair shader compound (Redshift) with volume scattering, illumination parameter isolation, and textured variation visualization,
- ICE nodes for both Sim & Styling based on Kinstinka, Melena, GroomTools, (+ some of my own nodes) and StrandCollisionFramework
- means to easily setup everything,
- many (old and recently added) features!
There is also a more or less similar MentalRay shader compound that could be re-emplemented with a bit of work. (currenly not included)
HairDew1.0.zip
Play tutorial / overview (in full screen)
Download tutorial / overview :: HairDew1.0 - Overview Tutorial.mp4
Other than the hair shader, the character's material has a "Redshift Material" general purpose shader encapsulated in compound
- For more organized exposed ports on node
- and for easy adding / editing parameters or layout
- shader compound adds "Diffuse Fresnel"
- a split-off of transparency / transmittance parameters from main first tab, into a new tab
- & more pleasant OGL display using Diffuse color as ambient
(for display only, globally adjustable with the global ambient setting)
I don't know how many are setup to use it (you can dowload the Redshift demo if you'd like to try) ,
nevertheless, I would be delighted to see results, tests, or especially descriptions of first experiences ( you can PM me or post here ! )
And... have a nice hair day !
Re: Softimage Garage | HairDew 1.0
Wow, excellent work! I miss SI.
- Hirazi Blue
Re: SoftimageGarage | HairDew 1.0
Impressive... Looking forward to its release!!!
- wireframex
Very nice addon
And I also missed these smileys
Re: SoftimageGarage|HairDew1.0
Hi! link added in first post!!
cheers!
(PS: If you downloaded just as it was posted, download it again because some items were missing. thanks! )
cheers!
- Hirazi Blue
Great! Thanks a lot!
But please release the Mental Ray compound as well.
I let my Redshift-license expire so now all I have is "good old" Mental Ray...
yes "But please release the Mental Ray compound as well. "
okay for the MR shader, yet I'll simply post an earlyer scene (which didn't have helper scripts or other things..)
but from which you should be able to export the shader as a compound, or make a model with the Styling pointcloud (with the shader) along with the lights,
and import the model in the new posted scene above, switch it to MR, and replace the RS shader with the MR one. (copy paste)
Also again, if you downloaded the posted scene earlyer, you may want to do it again, I left the display transparency muted, and other stuff lol (ignore if your scene looks fine)
later!
later!
- wireframex
Thanks a lot man !
A Softimage Cycles shader will be great
Phil
Phil
it works with Cycles shader ???
wireframex wrote: ↑17 Feb 2019, 22:05 Thanks a lot man !
Phil
Hi,wireframex wrote: ↑17 Feb 2019, 22:05 Thanks a lot man !
Phil
it should work with anything that can render strands, therefore pretty-much any renderer that works in XSI
Hi, did you mean getting the strands to render in sycles? if so, I suppose the cycles hair shader should work (?)wireframex wrote: ↑17 Feb 2019, 22:05 Thanks a lot man !
Phil
Otherwise just to clarify, I was of course not inferring that the supplied shader would work in cycles
wb FXDude
Very nice.. this fills a big gap! Not so many solutions for simulating long hair available, maybe just two? Can only come up with Ornatrix and *shudder* nHair at the moment, any more out there?
This seems to keep up well with the feature sets they have... going to have a dive in a bit soon...
Thanks and no prob!
Also note that my RS ver installed is 2.5.60, Mar 6 2018
I'm mentionning that because some earlyer versions couln't handle scattering.
Cheers!
Cheers!
Users browsing this forum: No registered users and 34 guests
