RCTOOLS 4.2 for Softimage 2011
Stephen Blair has compiled a 64 bit Softimage 2011 compatible version of "rctools 4.2".
You'll find it at his eX-SI Support Blog: go there now
So what are the rctools you ask:
the rctools are a venerable package of
"advanced selection tools and filters for Softimage|XSI"
(and now for Softimage also, obviously)
written by Reinhard Claus (rray)...
Re: RCTOOLS 4.2 for Softimage 2011
great news
got problems with sp1 32 bit. hope i find a solution.
NONSENSE ALERT:
as Stephen Blair points out in the following post, this post is incorrect...
Don't know, if this will help, but the "xsiaddon" Stephen Blair uploaded might be advertised as "for 64 bit", but does seem to include the 32 bit version also (as far as I can tell from studying the xml, as I don't have any 32 bit OS with SI installed at hand to properly test this).
- xsisupport
Nope, I didn't compile the 32-bit version of RCFilters yet.Hirazi Blue wrote:Don't know, if this will help, but the "xsiaddon" Stephen Blair uploaded might be advertised as "for 64 bit", but does seem to include the 32 bit version also (as far as I can tell from studying the xml, as I don't have any 32 bit OS with SI installed at hand to properly test this).
I stand corrected...
As there seemed to be SOME 32.dll's in the xsiaddon I wrongfully assumed all of them were available.
ok good to know !!
i need many other plugs which runs only with 32bit...so i cant change to 64bit again...
- xsisupport
I'll try to get the 32-bit version out some time in the next couple of days.
great news !
- xsisupport
The 32-bit version of rctools is available.
Thanks again for your work on compiling this! I regularly failed at getting the c# part to compile properly.
got an error again with the 32bit version.
' ERROR : Objekt erwartet - [line 124 in C:\Users\design03\Autodesk\Softimage_2011_SP1\Addons\RCTools\Application\Plugins\rcPopupPlugin.js]
' ERROR : 2006-CUST-rcPopup - Unexpected failure.
rcPopup
iCmd = DisplayPop ("&Complete all loops;&Walk loop (rcLoopWalk);&other loop ops[&Complete all loops (around corners);Complete all edge&rings;---;&Grow loops (rcLoopGrow);&Shrink loops (rcLoopShrink);---;Grow to &Island];"
I got the same error message, just install xPOP2 and it will work. You can download it from rray.de .
Thanks you for help,
Now it's work fine but got an error message on startscreen (error with the rctool filter) mhhh...
Anyway love this plug.
Could you please post the text of the error message you're getting?
Could it be the one concerning the "rcCustomFilterSettings" Stephen Blair mentions in the comments to the 64bit version of this plugin?
(quoted from here)To get rid of the “ERROR : 2356 – This plug-in is not installed: rcCustomFilterSettings” delete %XSI_USERHOME%\Data\Preferences\Custom Filters (RCTools).Preset.
RCTools crashes Softimage 2011 SP1 whenever I try to complete a loop (or all)
Resolved via deleting the old preferences file as well...
