RCTOOLS 4.2 for Softimage 2011
Re: RCTOOLS 4.2 for Softimage 2011
I have to confess I went completely out of the loop concerning compiling with C#
Will look a bit into that tomorrow.
Updated the C# part with the 2011 Adv.Pack libs -
Also added a new command (fill polygon selection) & updated the docs
Not sure if it works everywhere - let me know if not
- Attachments
- RCTools43(SAP).zip
- doc is inside xsiaddon. use menu to access
- (545 KiB) Downloaded 781 times
- eternal art
The link is not working , it's say :
The selected attachment does not exist anymore.
edit : now it's working , thanks
Download works here. I might be that you downloaded it in the second while I was updating the file.
Is it safe to install it ? Im with XSI2012 and the comments on the web site worry me )
I'd suggest installing the newer version 4.5 from this link here. Has a few additional options like subselection boolean ops, fill selection etc.
Well, i cant make it run on XSi2012
Im with Opera and when i try downloading from the link it opens page full with code...if i try to save linked content it saves it as HTML... if i save as HTML and then rename the file to .xsiaddon and drag to XSI view it gives some error... but its installed. When i map a key and try running it.... the error above happens....
i dunno, it will be nice to ZIP that file!
Im thinking about having problem downloading this file, but this might not be.' ERROR : Object expected - [line 46 in C:\Users\cauac\Autodesk\Softimage_2012\Addons\rcTools\Application\Plugins\rcPopup45.js]
' ERROR : 2006-CUST-rc45Popup - Unexpected failure.
rc45Popup
Here's it zipped but that shouldn't be the problem.
Could you look in the plugin-manager if there's an entry under UserRoot->rcTools->XPOP for RCTools Python Plugin?
If there isn't, there might be a problem with the python installation--- In the script editor, does python appear in the list of scripting languages?
- Attachments
- rcTools45.zip
- (555.43 KiB) Downloaded 112 times
No man, i dont know where to look for Python etc...
This is the only thing i get in the script editor
InstallCustomPreferences "rcCustomFilterSettings", "Custom Filters (RCTools)"
CopyPaste , "C:\Users\cauac\Desktop\rcTools45.xsiaddon", "Scene", 2
CreatePrim "Sphere", "MeshSurface"
ActivateRaycastEdgeSelTool
rc45Popup
Uh... I get this on installation:
' ERROR : 2028 - Invalid argument specified. - [line 31 in C:\Users\marc\Autodesk\Softimage_2012\Addons\rcTools\Application\Plugins\rcCustomFilters.vbs] '
SI-2012 x64 on Windows 7-64 Ultimate
Any idea?
Any idea?
This error should appear only once after installation, and disappear after restart.
Pimeto, in each script editor there a menu at the top that shows the available scripting languages. Is python included in there?
No I have only Vscript and Jscript ? \
This is it right ? http://www.python.org/download/releases/3.2/
I have installed this and XSI doesnt find it ? Is there any specific way to install it, or something else to install for XSI ?
Im sorry for being such a noob right now, but i have no idea of programming stuff and this python...
- Hirazi Blue
First of all: that's the wrong version of Python, Softimage runs with Python 2.6.x or earlier.
Second of all: From the path in your previous post I gather you are using SI2012. From SI2011 upward Python should be installed "automagically" with your Softimage install, you should only have to tell Softimage to "Use Python installed with Softimage" in the Scripting Preferences. (Look here)
Thirdly: If you really want to/must install an "external" (i.e. not installed with Softimage) Python, follow the steps described here, as you will have to install not only Python, but a corresponding version of pywin32 also...
And feel free to ask if anything is still unclear, obviously... ;)
Hey there. I just want to thank you for this awesome tool collection - it has saved me MANY hours of work on my current project.
Cheers,
Leo
Cheers,
Leo
Users browsing this forum: No registered users and 37 guests
