It is currently 24 May 2013, 22:05
Forum rules
The administrators and moderators of this forum try to edit or to remove entries with questionable contents as fast as possible; however, it is impossible to check every individual message. By submitting this approval you accept that each contribution in this forum shows the opinion of its author and that the administrators, moderators and operators of this forum are only responsible for their personal contributions.
You commit yourself, neither to publish in this forum insulting, obscene, vulgar, defaming, violence gloryficating nor other postings with indictable content. Offenses against this rule lead to immediate and permanent suspension. The operators reserve the right to pass the corresponding connection data to the criminal prosecution authorities. You grant the operators, administrators and moderators of this forum the right to remove, edit or relocate contributions at their own discretion. You agree that the data gathered during registration are stored in a data base.
This system uses Cookies, in order to store information on your computer. These Cookies contain none of the information indicated above, but serve exclusively for a convenient operation. Your mail address is used only for the acknowledgment of the registration and if necessary for the delivery of a new password.
By completing the registration you agree to these conditions.
1. Be kind to each other, because this is a support-forum and no flame-forum. Insulting statements are unwanted in any case. Asssure that discussions are always led objective and do not end in a personal battle. Resolve issues outside the board or consult a moderator.
2. Please post new contributions on-topic, that means relevant to the subject/range of topics and phrase expressive Thread titles! "Help" or "problem!" can be mentioned in the thread, but please not as topic heading. The title should display the basic problem - thus generally results in more and better responses which is also in your own self-interest.
3. If you have reported a concrete problem, please post a feedback whether one of the proposed solutions has solved it. It is simply annoying, if someone is still reflecting about a problem but the solution has been found long before.
4. Commercial issues should stay in the background. In first place this forum is here to inform about certain developments, not to advertise them aggressively.
5. Leave politics outside please. Here we want to exchange experiences. That is primarily an appeal to you, but experiences revealed that political threads heat-up the emotions and the climate of public opinion suffers heavily.
6. The responsible person can ban individual forum users, who violate deliberately against these rules.
7. For each forum-participant one log-on is authorized. In case a user creates several accounts and various nicknames without a good reason, depending on the situation, all accounts may be blocked.
8. Avoid unnecessary, as well as double- and triple- postings.
9. No proposals / postings / threads to right-wing extremists offers or similar unconstitutional contents. This applies to avatars as well as to signatures.
10. Signatures and graphics attached to a thread shall not affect the readibility of the page.
11. Avoid all kind of links containing reference-ID´s containing illegal stuff for example stolen software, stolen videos or stolen music.
Thank you,
your "www.si-community.com" team ;-)
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
 Post subject: DISCLAIMER & Guidelines
PostPosted: 09 Jun 2009, 07:24
Please refer to our guidelines you can read above..!
Thanks,
the team
DISCLAIMER
1. Haftungsbeschränkung
Die Inhalte dieser Website werden mit größtmöglicher Sorgfalt erstellt. Der Anbieter übernimmt jedoch keine Gewähr für die Richtigkeit, Vollständigkeit und Aktualität der bereitgestellten Inhalte. Die Nutzung der Inhalte der Website erfolgt auf eigeneGefahr des Nutzers. Namentlich gekennzeichnete Beiträge geben die Meinung des jeweiligen Autors und nicht immer die Meinung des Anbieters wieder. Mit der reinen Nutzung der Website des Anbieters kommt keinerlei Vertragsverhältnis zwischen dem Nutzer und dem Anbieter zustande.
2. Externe Links
Diese Website enthält Verknüpfungen zu Websites Dritter ("externe Links"). Diese Websites unterliegen der Haftung der jeweiligen Betreiber. Der Anbieter hat bei der erstmaligen Verknüpfung der externen Links die fremden Inhalte daraufhin überprüft, ob etwaige Rechtsverstöße bestehen. Zu dem Zeitpunkt waren keine Rechtsverstöße ersichtlich. Der Anbieter hat keinerlei Einfluss auf die aktuelle und zukünftige Gestaltung und auf die Inhalte der verknüpften Seiten. Das Setzen von externen Links bedeutet nicht, dass sich der Anbieter die hinter dem Verweis oder Link liegenden Inhalte zu Eigen macht. Eine ständige Kontrolle der externen Links ist für den Anbieter ohne konkrete Hinweise auf Rechtsverstöße nicht zumutbar. Bei Kenntnis von Rechtsverstößen werden jedoch derartige externe Links unverzüglich gelöscht.
3. Urheber- und Leistungsschutzrechte
Die auf dieser Website veröffentlichten Inhalte unterliegen dem deutschen Urheber- und Leistungsschutzrecht. Jede vom deutschen Urheber- und Leistungsschutzrecht nicht zugelassene Verwertung bedarf der vorherigen schriftlichen Zustimmung des Anbieters oder jeweiligen Rechteinhabers. Dies gilt insbesondere für Vervielfältigung, Bearbeitung, Übersetzung, Einspeicherung, Verarbeitung bzw. Wiedergabe von Inhalten in Datenbanken oder anderen elektronischen Medien und Systemen. Inhalte und Rechte Dritter sind dabei als solche gekennzeichnet. Die unerlaubte Vervielfältigung oder Weitergabe einzelner Inhalte oder kompletter Seiten ist nicht gestattet und strafbar. Lediglich die Herstellung von Kopien und Downloads für den persönlichen, privaten und nicht kommerziellen Gebrauch ist erlaubt.
Die Darstellung dieser Website in fremden Frames ist nur mit schriftlicher Erlaubnis zulässig.
4. Datenschutz[1]
Durch den Besuch der Website des Anbieters können Informationen über den Zugriff (Datum, Uhrzeit, betrachtete Seite) gespeichert werden. Diese Daten gehören nicht zu den personenbezogenen Daten, sondern sind anonymisiert. Sie werden ausschließlich zu statistischen Zwecken ausgewertet. Eine Weitergabe an Dritte, zu kommerziellen oder nichtkommerziellen Zwecken, findet nicht statt.
Der Anbieter weist ausdrücklich darauf hin, dass die Datenübertragung im Internet (z.B. bei der Kommunikation per E-Mail) Sicherheitslücken aufweisen und nicht lückenlos vor dem Zugriff durch Dritte geschützt werden kann.
Die Verwendung der Kontaktdaten des Impressums zur gewerblichen Werbung ist ausdrücklich nicht erwünscht, es sei denn der Anbieter hatte zuvor seine schriftliche Einwilligung erteilt oder es besteht bereits eine Geschäftsbeziehung. Der Anbieter und alle auf dieser Website genannten Personen widersprechen hiermit jeder kommerziellen Verwendung und Weitergabe ihrer Daten.
5. Besondere Nutzungsbedingungen[2]
Soweit besondere Bedingungen für einzelne Nutzungen dieser Website von den vorgenannten Nummern 1. bis 4. abweichen, wird an entsprechender Stelle ausdrücklich darauf hingewiesen. In diesem Falle gelten im jeweiligen Einzelfall die besonderen Nutzungsbedingungen.
Quelle: Disclaimer von Juraforum.de & Experten-Branchenbuch.de
http://www.pixelpanic.de
http://www.softimage-uebertage.de - international SOFTIMAGE Usermeeting 2012
