Excellent Compound ! Works super, super handy Thank's lot !
In the "Delete Polygons" sub-compound, I just exposed the "less than equal" second value. It react as a threshold RVB value to delete more or less polygons.
One question : In the "Crack Modeling" video, there is a "Filter Edge By Angle" compound.
Where can I get it ?
Again, Thanks for the great work !
AI Cut Geometry By Alpha
AI Cut Geometry by Alpha
This ICE compound cuts polygon meshes by any stencil image/image alpha which is UV-projected
on it. Usage video is available here, coproduced by MJD's friend Nour Almasri. This video by Fabricio Chamon shows how to create a cracked surface using FX Tree painting and
the AI Apply Thickness plugin (which is also written by MJD Boukhari).
This compound was introduced by MJD's coworker at AI-Production and si-community user eternal art in the thread linked below.
local backup: AI Cut Geometry By Alpha.xsicompound
Re: AI Cut Geometry By Alpha
Maaan i have good news for you ! You are Rock ! Thx you !
Oops ,something went wrong
olivier jeannel wrote:Excellent Compound ! Works super, super handy Thank's lot !
you can find it here:
viewtopic.php?f=19&t=1933
I'm not getting the same nice results with 2014, anyone has the same problem?
Eu é que tou com cenas? Tu é que tás com cenas!
http://lickingtheice.tumblr.com
http://www.mariodomingos.com
" I'm not getting the same nice results with 2014, anyone has the same problem? "
Installed in softimage 2015 WIN7x64 sp1, started testing -1 times worked (as in the attached video- from the alpha channel of the logo xsi, the geometry was obtained! Further the compound ceased to work correctly, makes geometry, but some kind of squares! tested on other versions of 2013, 2014, the result is the same.
The result is a need for version 2012 SAP - as in the demo video
Who does the compound work correctly, and with which version of the softimage & windows OS ?
The problems were in a falling off texture projection, everything works in softimage 2015
Users browsing this forum: No registered users and 74 guests
