This compound is in response to a thread on xsibase. You can add a particle attached to each object in models/instances.
* Create a group containing the objects inside of the model. (ie. ObjectGroup)
* Create a group containing the model and instances. (ie. InstanceGroup)
I tested animating the position and rotation of the objects, model, and instances.
-David Wigforss
Hopefully it works for you; I take no responsibility if it doesn't....
DW_AddParticleToModelsAndInstances
Add Particles to Models and Instances
This compound is in response to a thread on XSIBase. You can add a particle attached
Create a group containing the objects inside of the model. (ie. ObjectGroup) Create a group containing the model and instances. (ie. InstanceGroup).
local backup: DW_ColorBlendModes.xsicompound
- DW_AddParticlesToModelsAndInstances.xsicompound
- Create a particle for each object in a model/instance. Created By: David Wigforss
- (39.68 KiB) Downloaded 200 times
