New Cage Deformer
Positive Mean Value Coordinates Deformations
A new ICE based cage defomer utilizing positive mean value coordinates (PMVC) resulting
in a deformation with superior quality to that of the factory/legacy cage deformers.
(PMVC is described in this Eurographics paper by Yaron Lipman et al.).
One requirements has to be met which is that the deformed object must be fully enclosed by the cage object.
local backup: PMVC_deformer.xsiaddon
Re: New Cage Deformer
This (link) is the addon I tried (it has the paths fixed) .. needed an app restart. What I tried and what worked was: object fully inside the cage, and the "sparse" checkbox ticked, otherwise I would get a crumpled mesh. Used a quad mesh.
Thanks, I'll give it another go later today.
Hi Dan,
Would you be on 2015 by any chances? If yes, I've just posted a scene with the 100% ICE setup on the softimage list.
Please not that in this case the cage have to be triangulated.
I hope you'll get it working!
Hi Ahmidou,
I've had a little trawl through the mailing list but can't find the ice setup, any chance you could post a link here?
Matt
Matt
Hi Ahmidou, you have a syntax error in your plugin which is preventing it from working.
There is an Activeprimitive (lower case p) around line 60 which needs fixing. All working now (with the version rray posted that also has the fixed hard-coded paths in the addon)
Dan
Dan
Thanks Dan, I'll fix that on my side.(weird that it was working for me)
About the scene I posted on the list, it's waiting for approval, because of the it's size.
it's also 22Kb bigger than the allowed file size in this forum :/
I'll try to reduce it's size tonight.
Users browsing this forum: No registered users and 52 guests
