SiScatter
SiScatter 2.0
A scattering plugin from Julien Carmagnac, author of »Instance On Curve«.
SiScatter offers a high level of control over the scatter placement:
This scatter tool distributes particles based on the »emTool _ Equal Distribution on Surface« Compound from Eric Mootz (thank you Eric !). I tweak this compound to work together with »Delete Particles Near to Boundaries Edges«, »remove closest geometry« and »remove inside filter« compounds.
This tool build an ICE Tree and create a custom property under the point cloud object to tweak all ICE parameters. So you can edit entirely your scattering without open your ICE Tree. List of avalaible modifiers: color by gradient color by shape id color by texture map filter by boundary edge filter by closest geo filter by fractal filter by random [..]
Continue reading in the si-community thread. Video demo here.
local backup: siScatter.xsiaddon
- cheeseburger
Re: SiScatter
Hi julca,
Can you just explain the number and density ? It seems everytime I move one the other moves as well so I don't understand. I would like to use a very specific number, is that possible ?
Thanks please excuse my simple question. Awesome tool by the way !
Re: SiScatter
Of course,
The number and density parameters does the same thing but in two differents ways :
If you have any other questions I'm available to answer it.
- - If you adjust the density (= number by xsi unit), then the number parameter are adjusted to reflect exactly the density according to your emitter area.
A grid emitter (1*1) with a density of 1 = 1 particle
A grid emitter (2*2) with a density of 1 = 4 particles
A grid emitter (2*2) with a density of 2 = 8 particles
etc.
So if you change your emitter object, you keep your ratio of particles and so, the aspect of your scattering.
- - If you want a specific number (without considering all filters parameters),
just edit the number parameter (and the density will be adjust to reflect this number).
- cheeseburger
Re: SiScatter
So the true number is just the number parameter and the density useful when wanting to maintain a density despite actual number and emitter ? Wow, very cool !
- cheeseburger
Re: SiScatter
Hi julca, one more question ... How can you control the specific number of instances within the various shapes ? E.G. If you have 10 shapes, how can you have say 12 of shape 1, 3 of shape 2, 9 of shape 3 etc ?
Cheeseburger
Cheeseburger
Re: SiScatter
Hi, you can use the shape's weight to do that.
Set your number parameter equal to the sum of each shape's weight number.
Like in the screenshot below, you have 10 total particles and the sum of each shape's weight (3+2+5) give you 10. But you need to update manually the number parameter at each shape's weight modification.
I hope that help you.
- cheeseburger
Re: SiScatter
Hi julca, I have tried that but I'm not getting the same results. I have 38 different shapes(people on cards) and when I load them up I get this ... See image.
Am i doing something wrong ?
Cheeseburger
Cheeseburger
Re: SiScatter
If you set the number parameter at 38, you're should be ok.
But, my last suggestion works without apply the filters (closest, inside, etc.).
The number parameter is the number of particles before apply any filters.
- cheeseburger
Re: SiScatter
I tried setting the number to 38 and that image shows the results in the shapes page. It's strange. It could be something I'm doing but it's a pretty simple setup that I'm using. I'll try again just to double check
- cheeseburger
Re: SiScatter
Hi julca,
Yeah, turned off any other settings, put in 38 and I'm still getting strange readings ... arrrgh Help. Your plugin or addon is so fantastic, it's just this one little snag for me ... any other suggestions
Re: SiScatter
Oups, you're right !
I select shape ID by random and here the weight just influence the probability.
Let me take the time to find a workaround/update.
- cheeseburger
Re: SiScatter
Thanks julca ! Really appreciate it
Re: SiScatter
Hi cheeseburger,
I've updated the link of first post (version 1.2):
- Add a new emission parameter "Exact Shape Weight Sum" that drive the number of particles with the sum of all shapes's weight.
It also strictly set the number of shapes accordingly their weight.
- Correct update of shape info (number and percentage for each) when "Fractal Shape Selection" are enabled/disabled.
Now you can use shape's weight as the exact number of shape.
Like below, I have 6 shapes, the first one with a weight of 3 and the 5 others with a weight of 1.
The total of 8 (3+1+1+1+1+1) is automatically updated. Thanks for your feedback.
Cheers.
Cheers.
- cheeseburger
Re: SiScatter
Hi julca, that's great. That works well.
Now that Exact shape weight sum works great, is there any way you can still use Fractal shape selection ? Is that the equivalent to bunching ? It's an awesome option. It seems to work only when Exact shape weight sum is turned off.
Re: SiScatter
No it can't work with the other option because it's a fractal selection based on 3d space.
So by definition it can't maintain exactly the number of shapes (between them) as the option "Exact Shape Weight Sum" do.
Let me clarify the "weight" parameter for each shape :
- With "Exact Shape Weight Sum" : define the exact number of associated shape (usefull when you have many shapes and you want a tiny number of each)
- Without "Exact Shape Weight Sum" (default) : define the influence/weight of shape during a random selection (more manageable with large number of particles)
Hope that's clear.
Friendly.
Hope that's clear.
Friendly.
- cheeseburger
Re: SiScatter
Ok, got it. I suppose clumping with "exact shape weight sum" might be achieved through weight painting or something similar, what do you think ?
Re: SiScatter
Yes, in your case weight map might be a solution : define a zone for one scatter with one shape and set the number of particles you want.
Users browsing this forum: No registered users and 42 guests
