3delight tests
Blob Strokes
Here's a small ICE compound used to generate these 'blob-strokes'. I had something
like this before, but I really wasn't so excited by the speed of generation. Now with
3delight, it's definitely feasible, updates are performed immediately. The compound
creates particles on curve list, evenly distributed, count is relative to particular
sub-curve length (still, you'll need to take care of curve re-parametrization). It's
also able to perform 'write on' on one-after-another subcurve (by sub-curve, or normalized
by sub-curve length). In short, you can 'draw' 3d strokes with it, by animating the
slider value. There are a few additional parameters. [..] contd. under si-community link
local backup: Emit Blobs From CurveList.xsicompound
author site: http://www.matkovic.com / si-community thread
3Delight
v4.0.41 updated Feb 21st 2015. 3Delight is a fast, high quality, RenderMan®-compliant renderer designed to produce
photo-realistic images in demanding production environments. The renderer was introduced
to the public in the year 2000 after being used for more than a year as the sole renderer
in a sister production company. It is now widely used and earning a reputation as
a benchmark in rendering technology. [..] (cont'd on product page)
DNA research recently released the 4.0.41 upgrade along with making the free license now support up to 8-core CPUs. Highlights from the changelog: Volumetric Smoke and Shards Any shader as light source projection Exposure, Gamma Controls Mesh Light support ESC to stop render. Last year's big 4.0 update introduced features such as: support for deep EXR files Native MARI textures support Improved sampling of environment maps Added the physically plausible 3Delight Material "Continuous rendering" is now enabled by default Up to x2 acceleration in hair/fur rendering Memory usage is down 30% when using the path tracer Skin shader for 3Delight for Softimage Motion Map property is now supported
A list of movie project rendered with the 3Delight renderer. As mentioned the product is free of charge for the first 8-core license. Additional quad-core licenses are available for 400$ each and unlimited multi-core licenses for 900$ each. Yearly support and updates 190$/290$ resp.
company page: http://www.3delight.com / product page: /en/index.php?page=3DFS_features / resource base / si-community thread (updates) / si-community thread (render tests) /
Re: 3delight tests
Just standard xsi hair shader. I don't know anything about renderman shader programming.
Re: 3delight tests
Great! Well I really don't feel 'alone' in this thread, anymore...origin wrote:My hair tests with polish bison
Btw, all my Renderman knowledge is based on 'Smart Copy-Paste technology (TM)' . Definitively not enough for great stuff, but for adding a small changes here and there, more than enough. I'd believe that for 'thin' stuff, strands, leaves and so on, point based AO should consider 'both' faces.
Re: 3delight tests
what's the render time on that Bison, and where is the asset from?
Re: 3delight tests
It's my model for a client (vodka ad), rendertime around 15 minutes for 3k AFAIR (2 cores).
Re: 3delight tests
Nice bison!
- Contact:
Re: 3delight tests
bison is cool. and those SSS tests as well.
i did this a long time ago with version 2 i guess. a lot of displacement (simple grid and subdivided cubes) and hair and dof...
and some characters i did with 3delight:
http://www.milanvasek.com/newimgs/3d/ellieweb.jpg
http://www.milanvasek.com/wp-content/up ... rd_web.jpg
hopefully i'll put here more recent stuff soon
Re: 3delight tests
Yeah I remember this image from XSI base, but didn't knew it was yoursmilanvasek wrote: i did this a long time ago with version 2 i guess. a lot of displacement (simple grid and subdivided cubes) and hair and dof...
Still, real DOF gives something... outstanding, compared to 3d images on the internet.
Thanks for posting !
Re: 3delight tests
Hi. Will you be kind to share that scene (hair nad displacement), without maps. I like that hair, but I can't achieve that render quality. Thanks in advance.milanvasek wrote:bison is cool. and those SSS tests as well.
- Contact:
Re: 3delight tests
hi. I can try to find the scene, but i'm afraid it's lost somewhere on my old harddrive. anyway it was nothing special. few spot lights with volumic shadow maps, shading rate very low (i guess it was around 0.2, mostly because of all that displacement) and high oversampling. and some transparency on hair i think...doca wrote: Hi. Will you be kind to share that scene (hair nad displacement), without maps. I like that hair, but I can't achieve that render quality. Thanks in advance.
i can make similar scene again and share it (during weekend probably)
Re: 3delight tests
Thank you very much. I asked because I have problem to get good looking hair-I like soft shadows (AO look) on your render, and again, there is nice and recognizable volume of hair. Can you, remember settings for shadow maps?milanvasek wrote:hi. I can try to find the scene, but i'm afraid it's lost somewhere on my old harddrive. anyway it was nothing special. few spot lights with volumic shadow maps, shading rate very low (i guess it was around 0.2, mostly because of all that displacement) and high oversampling. and some transparency on hair i think...doca wrote: Hi. Will you be kind to share that scene (hair nad displacement), without maps. I like that hair, but I can't achieve that render quality. Thanks in advance.
Thanks again.
Re: 3delight tests
I like these! They're great!and some characters i did with 3delight:
- Contact:
Re: 3delight tests
cant really remember. but i used some kind of light dome (around 10-12 lights) to make that soft look and volumic shadow maps with big softnessdoca wrote: Thank you very much. I asked because I have problem to get good looking hair-I like soft shadows (AO look) on your render, and again, there is nice and recognizable volume of hair. Can you, remember settings for shadow maps?
Thanks again.
Re: 3delight tests
Hi all,
this time, a bit more about 'hair translucency' effect, especially noticeable on bright hairs. One simple method to get this effect is using of colored shadows.
That's how my trial looks like:
For 1280x1280, 2-core 3delight took about 8 minutes for render. There is 80k hairs, two spot lights with 1024 deep shadow maps. I've used only standard XSI shaders.
Take look at full res.
So how to get this in 3delight:
1: In global render options, under 'Shadow Maps > Shadow Map Shaders', enable 'Surface'.
2: Apply 3delight's 'Hit Mode' property, to Point Cloud with ICE strands.
3: In 'Hit Mode' property, enable 'Run Material' for Shadow Rays.
4: Enable 'Detailed Shadow Map' for your lights.
Step 3 is needed, because XSI Hair Shader doesn't allow colored shadows, even it can be used as a shadow shader. That's how it looks like when XSI Hair Shader is used for shadows too (on left side ).
So, we will supply another shader for shadows. Some recipe is a bit darker and more saturated color for Constant surface, some gray variance for transparency. Basic render tree looks like this one:
And that's all.
Tips:
Somewhere in installation folder, probably \Softimage\.....\Data\DSPresets\Materials\Hair, there is a lot of color presets for XSI Hair Shader. I've found them *very* usable.
Here I've used a 'Hair Golden Blonde'.
When rendering ICE strand segments, 3delight automatically does the curve interpolation. Generally, you should be able to use a much lower count of strand segments.
About mip-mapping for Deep Shadow Maps, it seems 3delight adjusts this automatically. Corresponding 'Sub-Samples' parameter seems it has no effect, even it's mentioned in the docs. On the other side, by watching render log, I've noticed reports about various mip-map levels. In short, I believe in 'common' rendering strategy - start with low-res DSM, but don't hesitate to increase it if needed.
And that's all.
Tips:
Re: 3delight tests
Wow, that's looking good! Thanks for all the info!
Re: 3delight tests
I used the same setup, only with a color savestate instead of the constant - no difference really.
It's a really nice setup, especially with a light rig generated from a HDR. I would say 30 lights or more make sense to get the most realistic lighting. Also had to increase shadow map resolution to 2048 to get rid of some shadow artefacts.
No problem to render this with 3delight's speeds even on my oldish laptop.
Just to add some confusion for those unaccustomed with them terms ...
Shadow map = 2 color-only shadow map, no transparency
Deep shadow map = Pixar's original "with tranparency" shadow map format (pdf)
Detail shadow map = mental image's version of deep shadow maps
Volume shadow map = Softimage's GUI name for MR detail shadow map
- Hirazi Blue
Re: 3delight tests
Moderator edit: I've reintegrated the slightly off topic discussion about the license problems ActionArt experienced (initiated by myself )
into the other 3Delight thread, where the posts seem to belong...
Users browsing this forum: No registered users and 63 guests
