It is currently 24 May 2013, 07:14
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3, 4, 5  Next
Author Message
 Post subject: End of the World.
PostPosted: 14 Jan 2012, 06:23
Offline
Hey, you want to destroy a city. For the moment the item is ready to bomb and then tear apart a couple of buildings as well. A bomb made ​​em fluid4 plugin. Great for the plugin. Continue soon.
_________________
http://www.behance.net/MasterMason
Top
 Profile
 Post subject: Re: End of the World.
PostPosted: 14 Jan 2012, 16:15
Offline
Looking nice. Would you mind posting a shot of the ICE tree? And maybe a little video of the effect?
_________________
Gustavo Eggert Boehs
Blog: http://www.gustavoeb.com.br/blog | Training: http://gustavoeb.com.br/blog/?cat=16&lang=en_us
Top
 Profile
PostPosted: 16 Jan 2012, 12:11
Offline
Hi, I make a pic later, and can be slow motion animation. Succeeded nicely set up the volume shaders and fast rendering. I hope you will get see.
_________________
Top
 Profile
PostPosted: 16 Jan 2012, 18:37
Offline
looks preaty good !
Top
 Profile
PostPosted: 03 Feb 2012, 15:19
Offline
Super_Slow_Motion_Simulation_Previz
There are other things too, so things go more slowly
Ice Nuclear Bomb
http://www.youtube.com/embed/BOxrdVXQ_-g
_________________
Top
 Profile
PostPosted: 04 Feb 2012, 10:05
Offline
Guys how to improve this?? Everything has been tried. BA_Shader...
_________________
Top
 Profile
PostPosted: 04 Feb 2012, 14:40
Offline
you could:
(1) not use any fractal in density, just use a LOT of particles... or
(2) you could use a mix or something in density and get a attribute from your particles as the weight for the mix... the same attribute used to switch inbetween fire and waste... (I dont know if that is clear enough, but Im not in front of SI right now to send any screengrabs)
_________________
Top
 Profile
PostPosted: 04 Feb 2012, 23:42
Offline
Ok, some images so I sound more convincing... Im getting a custom attribute into my render tree... As that scalar value is closer to 0 it falls toward the particle shaper, as values get closer to 1 it falls to regular round shape.
You could use some scalar math nodes to build a mixer and not have to convert values to color, but Ill leave that up to you ;)
_________________
Top
 Profile
PostPosted: 05 Feb 2012, 01:16
Offline
Thx Gustavo, I do not understand why mix the alpha two point clouds? I need to work on it.
_________________
Top
 Profile
PostPosted: 06 Feb 2012, 18:16
Offline
Just a test, smoke is not good, seems to be foam. Otherwise it is 100 frames in 4 seconds for 20 seconds in slow motion.
_________________
Top
 Profile
Search for:
Jump to:
