3d anime research
Comments on work in progress
anhungxadieu
Skype: nguyenvuducthuy
3d anime research
Post by anhungxadieu » 22 Dec 2015, 09:01
Hi si user,
This is a little research anime character in 3d. CC welcome.
Thank you!
https://drive.google.com/file/d/0Bz5Tvz ... sp=sharing
anhungxadieu
Re: 3d anime research
Post by anhungxadieu » 29 Jan 2016, 05:47
a little update
Post by Mathaeus » 29 Jan 2016, 13:08
Cool. Do you have plans to add some movement to entire character. Should invoke a more of simulation.
The renderer "turtle" used by this scene, is not currently available. The "turtle" renderer will be used instead.
anhungxadieu
Post by anhungxadieu » 29 Jan 2016, 13:48
thanks Mathaeus, :ymblushing:
sure, i will add more in future, now i'm doing some cloth things. I consider between simulation and unsimulation for anime character, for a dynamic anime's animation i think it's will be good if i don't invoke simulation, and it will give me more control later.
xsi_fanatic
Post by xsi_fanatic » 29 Jan 2016, 17:49
anhungxadieu wrote:thanks Mathaeus, :ymblushing:
Hi anhungxadieu,
For anime style, I highly recommend avoiding cloth simulation. If you're going for something stylized like Appleseed 2 ExMachina, then you could add some simulation, but I would limit it.
Here is what I would recommend.
- For hair, use Helge Mathee's mt_Spring plugin, downloadable here.
http://www.softimageblog.com/archives/259
- For rigging, I highly recommend Masashi Yamaguchi's myRig. Gives you everything you need in one simple humanoid rig, allowing you to control anything from cartoony to hyper realistic characters.
- Last but not least, keep the animation limited, and simple if you're going for an anime style in 3D. You can learn more tips from Guilty Gear's presentation.
All characters are 3D yet look convincingly 2D:
What rendering package are you using ?
All the best
anhungxadieu
Post by anhungxadieu » 30 Jan 2016, 03:54
well thanks xsi_fanatic,
regarding a movie from Guilty Gear's presentation. I watched again and again when i try to render cartoon style. They say everything just already there nothing new, you only need to find and practice :D. This render i use mentalray, I will post more research and questions also to here. :ymblushing:
anhungxadieu
Post by anhungxadieu » 30 Jan 2016, 09:18
chotto update!
this is a cloth i'm doing right no sim invoke
anhungxadieu
Post by anhungxadieu » 01 Feb 2016, 11:11
hi there,
simple muscle r&d .. still a lot of work so far :ymblushing:
Thank for watching!
anhungxadieu
Post by anhungxadieu » 10 Mar 2016, 10:56
xsi_fanatic
Post by xsi_fanatic » 11 Mar 2016, 11:30
Hi man,
This is looking so much better. I'm curious to know how you did the eyes and the mouth. Please share. I have to learn this :-t ^:)^
I did an anime character a while back and want to continue down this path. But it's hard to do a convincing anime in 3D especially when it comes to the mouth and the eyes.
Here's a post of my blog.
http://kungfuanimationproject.blogspot. ... -post.html
Full blog: http://kungfuanimationproject.blogspot.ae/
anhungxadieu
Post by anhungxadieu » 11 Mar 2016, 17:18
xsi_fanatic wrote:Hi man,
[/url]
hi thank you,
this still wip i still need to implement some more feature for the mouth actually, i will share some info about this to here ... :)
anhungxadieu
Post by anhungxadieu » 12 May 2016, 08:08
new update!
little test with hair ;;)
