The material cost is about $80-$100jamination wrote:I am curious, how much to print out 1 working figure.
3D model for 3D printing an action figure
Re: 3D model for 3D printing an action figure
Wanna see whales in giant mechsuits protect mankind against evil aliens?
Check out: http://mechawhales.com/
This is superb!
I was wondering if you could share your workflow.
Does the Mojo printer take a particular model file?
I looked that one up, would you say it could live in an office or too noisy?
I have dabbled with the printer we have at work. Its a few years old now and is a powder based machine and requires lots of work afterwards (sealing it with high strength adhesive). We are looking into 3d printing more so this post is very interesting!
We have just started to test the machine again and we will be looking to produce a mould to make a bronze casting (we have a bronze foundry in another department!)
Perhaps I can document it!
Cheers,
J
Cheers,
J
Mojo printer uses STL files for printing. It is roughly as loud as an inkjet printer. Maintenance is very easy and also removing the support material works very well. You can just dissolve it in a cleaning station that comes with the printer. However the printed parts lack the detail for final products. But it is great for prototyping. This link has some good info about the printer: http://www.engineering.com/3DPrinting/3 ... inter.aspxMadness wrote:This is superb!
Cheers,
J
The files were exported as obj files from Softimage and then converted to STL format via Zbrush. All that was left to do was to create the holes for the joints to plug into. I did this via Netfabb. In Netfabb it is very easy to do boolean operations so all I had to do was subtract the joints* from the geometry where they would need to be plugged in and I had my fitting holes. Netfabb also allows you to optimize your models for printing. I could import the obj files directly into Netfabb but the conversion via Zbrush allows me to export the STL files at the exact size I need the final figure to be.
* I actually made the joints 0.15mm larger for the substraction to have some room to plug them into the parts.
Here is another concept figure. It has fever joints then the others but is actually the most fun to pose. It is the first time I used a double jointed knee. I always thought double jointed knees and elbows looked weird but it does allow for a nice range of movement. I also gave this figure a split torso so the head, shoulder and pelvis joints are actually held in place by the two torso halfes rather then just plugged into the torso. A split torso with seams was another thing I thought might not look good but the seams can be hidden quite nicely. All in all I think this figure has the best ratio of articulation and sturdiness.
Here is a painted version of the alien cyborg. I am really happy how he turned out. The roughness of the print works quite well for the worn down bionics and the alien skin. The paintjob also does not get in the way of posing him. I hope to make more figures like him in the future.
I also set up a website for my 3D printed action figures you can see here: http://www.hauke-scheer.de/
- MauricioPC
Amazing work my friend!
I've been modeling a 'pet' for 3D printing. I've watched a tutorial on Lynda.com, on how to print on Shapeways with Maya. It gives some general ideas of the pitfalls and other things to look out.
Do you have any other resources that give a walk-through on the process or you discovered all by yourself? 3D printing is still to expensive for me to buy one, so I'll probably will use a service like Shapeways here, but I want to be the most cautious I can, because it's expensive.
Cheers and great work.
I pretty much taught myself everything via learning by doing. It helps just looking at other mass market figures and see how they are constructed. I am experimenting with Shapeways myself at the moment. On thing you should keep in mind is that their different materials use different printers with different requirements. So it helps to decide beforhand which material you want your figure to be printed on.gonebadfx wrote:Amazing work my friend!
This guy is called Steracorilla because well he is a mix of a styracosaurus, a stegosaurus and a gorilla. He was basically an experiment to see how I could give my box modeled action figures a little bit more texture using Zbrush. Therefore I made the base model in Softimage using traditional modeling tools. I then exported the files to Zbrush and masked off the parts that would have to stay smooth in order to make the joints work. The other parts got a rough surface using Zbrush brushes. The figure was then exported as STL file and finalized in Netfabb. The textures showed up fine after the print even on my Mojo printer that does not have a super high resolution. Especially once I painted the model the skin textures looked quite nice. I will continue to use Zbrush in the future to add fine detail like skin textures or scratches.
Here is the painted 3D printed Steracorilla figure in action.
Users browsing this forum: No registered users and 18 guests
