Page 1 of 9
OpenVDB to Softimage
Posted: 22 Dec 2013, 22:07
by Mr.Core
Hi All,
i made the initial openvdb plugin connector to Softimage, currently its version 0.8 because of not fully tested and can be buggy. Also, many tools from openvdb lib is not implemented yet. Many thanks to houdini connector authors and Steven Caron for snippets of code. What is the Openvdb and its capabilities you can see here:
http://www.openvdb.org/documentation/
And be sure to check out the coolest dreamwork pdf on the subject
http://www.openvdb.org/download/openvdb_dreamworks.pdf
Here is my little test on rendering houdini's explosion inside of xsi with arnold:
https://vimeo.com/82154098
You can download plugin ( free for comm and noncomm purposes of course ) here:
https://dl.dropboxusercontent.com/u/371 ... e_v0.8.rar
The arnold shareds are compiled against sitoa 3.0, the sample scenes is for 2013 and up. The redistributable required as always
http://www.microsoft.com/en-us/download ... x?id=30679
cheers
Re: OpenVDB to Softimage
Posted: 23 Dec 2013, 03:55
by Daniel Brassard
Good job, well done.
Thanks for the plugin. I'll test it an give you feedback.
Cheers and Happy Holidays!
Posted: 23 Dec 2013, 05:56
by Bullit
The Dreamworks PDF looks amazing. Can you tell in succint way what you think what should be the integration steps in Softimage?
I think LS animation to fog, Combining grids, volume stamping , volume deformation, particle surfacing seems most interesting, this only after a cursory look.
Posted: 24 Dec 2013, 19:50
by scaron
Bullit wrote:...Can you tell in succint way what you think what should be the integration steps in Softimage?
i don't follow, 'integration steps'? oleg did the integration of the library into ICE, you have the tools to manipulate volumes now.
Posted: 25 Dec 2013, 11:31
by wotty33
Fantastic toolset, thanks so much! Quick question: what's the correct Ice node combination to write vdb grid data out of ice (so you can read it back onto the shader). Found the io node but not sure what you plug it in to?
Posted: 25 Dec 2013, 15:21
by Mr.Core
@wotty33
it's pretty straightforward, all what you need is to put some grid on input, set "Write" mode, specify your .vdb file name and name of your grid, and make it all evaluating. See the screenshot for example
@Bullit
I misunderstand this too, can you rephrase it please ?
Posted: 25 Dec 2013, 16:43
by wotty33
Mr.Core wrote:@wotty33
Thanks a lot! This is so useful. It's the perfect solution for a couple of shots I've got going at the moment. Now back to the turkey.(or veggie nut roast in my case)
Happy Christmas from the uk!
Cheers, Paul
Posted: 26 Dec 2013, 03:35
by Bullit
Thanks for feedback. Following that quote i am thinking that some capabilities that appear in Dreamworks.pdf are missing.
Posted: 26 Dec 2013, 10:07
by telepatam
amazing work so far, fluidy volumy stuff is what softimage needs the most especially on the rendering side.
Posted: 01 Jan 2014, 17:31
by amr_helmy
amazing work
i am new user to softimage
i cant find the vdb _ai shaders
i only find vdb has _mi shaders
how can i show the ai shaders
Posted: 01 Jan 2014, 19:18
by Bullit
Shaders should be in rendertree no?
Posted: 02 Jan 2014, 11:47
by Ahmidou
Great work Oleg, and thanks for sharing, this such a usefull tool.
Posted: 02 Jan 2014, 14:33
by Mr.Core
attach please your plugin manager' state screenshot, screenshot with logged errors. Did the mi shaders work for you ? Did you extract the arnold shaders into the sitoa dir ?
Write me all your steps, otherwise I dont know what is going on
Posted: 02 Jan 2014, 16:29
by Rork
Also...
The arnold sharders are compiled against sitoa 3.0,
So unless you're running the latest beta core of Arnold, this is not going to work anyway.
Posted: 02 Jan 2014, 16:50
by amr_helmy
Mr.Core wrote:>>i am new user to softimage
the mi shader doesnt work , and i followed the step and put the dll file in its place
here screen for arnold version and error that i got and plugin manger
thanks
Posted: 02 Jan 2014, 17:27
by Mr.Core
well, seems like something is messed up, because i see warnings about conflicting versions. To be sure, delete all openvdb stuff ( workgroups with ice nodes\arnold shaders from the sitoa folder ). then, 1) redownload archive 2) unpack and connect the VDB2SI_WG folder in the plugin manager 3) unpack the "extractToSITOAdir" into the C:\Users\username\Autodesk\Softimage_XXX\Addons\SItoA\Application\Plugins\bin\nt-x86-64 4) restart XSI
also you need to have installed vs2012 redistributable
First of all, mental ray shaders ( mi ) must work even if the arnolds package is not found
