Quick Cache 2
Quick Cache 2
This plugin helps you cache point clouds, meshes and curves in a quick and efficient
way [..]
The main feature of the new version is the ability to cache multiple particle clouds at once. Now it's more stable also, you can try to break it by selecting all objects around, push buttons in a chaotic manner and do crazy stuff with selections - it will work properly no matter what. Changelist: Caching is now works on ICE. Work in the production environment showed me that standard caching via Cache Manager is not working for complex simulated pointclouds. Cache loads within the one object now. It's achieved by the disabling construction stack logic that allows you to save original simulation ice trees and get a cached version speed on a preview and render at the same time. It's means that your shader and settings of the point cloud will be applied to cache also. Added »Folder« button that opens cache folders of the selected objects. Video is now recording to png mov format. This is the smallest and best quality video format that is available. You can disable video recording now if you want to. Added samples checkbox for subframe sampling of the simulated point clouds. Default settings of the ppg can be changed in a SIQC_Defaults.py file
Installation: copy »QuickCache« folder into »ApplicationPlugins« user folder and restart Softimage. To add it into a scene, go to Model -> Property -> QuickCache Introduction video at youtube.
local backup: QuickCache.rar
Re: Quick Cache 2
Link is updated!
Major change of this version is that substeps now stored in a folder with cache, so if you cache cloud with different simulation step values it will be loaded properly
"Retime" button opens ppg for selected objects only should work as it says
Small annoying things that nobody cares except me is fixed also
Installation help file is now included
- Hirazi Blue
Re: Quick Cache 2
Just a friendly suggestion: when you update the link it might be an idea to change the filename to include some kind of version number (something like "QuickCache_02.rar" for instance), so people can easily see, if they have already downloaded the most recent version...
Re: Quick Cache 2
Everyone who want download the latest version can download it from the first post, or check files modification timeHirazi Blue wrote:Just a friendly suggestion: when you update the link it might be an idea to change the filename to include some kind of version number (something like "QuickCache_02.rar" for instance), so people can easily see, if they have already downloaded the most recent version...
It's seems like version from the first post is the latest one, because I have no idea how to improve it further - everything works fine for me
- bottleofram
Re: Quick Cache 2
Well, let me spoil your party, than. Earlier i could cache the geo with regular operators applied, they just needed to be in the modeling stack. Now, it spits out this error:
I still think it would be useful if you could support non ice based deformers. Just a thought.
' ERROR : 2000 - Argument 0 (Target) is invalid
' ERROR : 2001-GetValue - Argument 0 is invalid
' ERROR : Traceback (most recent call last):
' File "<Script Block >", line 170, in QuickCache_Cache_OnClicked
' qc.cache()
' File "C:\Users\alex\Autodesk\Softimage_2012_SP1\Application\Plugins\QuickCache\SIQC_Cache.py", line 197, in cache
' if si.GetValue(path+".simulationsettings.subframesampling") != 1:
' File "<COMObject <unknown>>", line 2, in GetValue
' COM Error: The parameter is incorrect. (0x-7ff8ffa9) - [line 169 in C:\Users\alex\Autodesk\Softimage_2012_SP1\Application\Plugins\QuickCache\QuickCache.py]
' ERROR : Property Page Script Logic Error (Python ActiveX Scripting Engine)
' ERROR : [167] def QuickCache_Cache_OnClicked():
' ERROR : [168]
' ERROR : >[169] import SIQC_Cache as qc
' ERROR : [170] qc.cache()
' ERROR : [171]
' ERROR : [172] def QuickCache_Play_OnClicked():
' qc.cache()
Re: Quick Cache 2
And that's totally cool! Fixed, thanks! And I removed the progress bar also to see the timeline betterbottleofram wrote:Well, let me spoil your party, than.
It's already supports non-ice operators, I wrote about this earlierbottleofram wrote:I still think it would be useful if you could support non ice based deformers. Just a thought.
- bottleofram
Re: Quick Cache 2
Awesome. Everything seems alright now.
If you, by any chance, need an idea how you could improve it further, heres one: tokens in path. I realize you probably made the plugin for quick-and-dirty purposes, but say you are working on different scenes (or even different projects) and forget to change that path string. Things could get messy...
In that case something like "C:\Cache\[scene]" or "[Project Path]\cache\[scene]" would come in handy.
Re: Quick Cache 2
Great idea!bottleofram wrote:Awesome. Everything seems alright now.
I've added [Project Path] and [Scene] (case sensitive) tokens, now path is set to "[Project Path]\Cache\[Scene]" by default, but, of course, you can change it in a SIQC_Defaults.py at any time
Link from the first post updated (33 kb overall size, not a big deal to download it again if you don't know what version do you have)
Re: Quick Cache 2
I've got another question/feature request:
I tried out the retimecompound you included and it didn't interpolate between frames when I set a lower than 100% speed. Is that right or does it depend on attributes in the cache - like subframes, prevpointposition, prevvelocity? Or am I just doing something wrong?
What would be really good to have is a 'cache on file'-compound with retimecapabilities built-in, with options to toggle between different kinds of interpolation - linear or splined - and an intuitive way of setting up keys. A f-curve editor with visible timelinecursor and precise editing of keyframes, I think. The ICE mini-graph like the one in your compound gives no options like these, which makes it kind of useless IMO.
Is this at all possible or is it way outside of the scope of your approach for a quick system?
Maybe this would be a compound that deserves a life by it's own, as a replacement for the factory cache on file node.
thanks, Jasper
thanks, Jasper
Re: Quick Cache 2
druitre, this is not not a replacement of standard cache tools, it's just quick way to use them instead. I'm not interpolating anything, to retime it with very low speed you need higher simulation substeps number (something like 6 or 8). The reason is: I don't need that feature, so I don't care about it, sorry
Re: Quick Cache 2
[rimg=400]http://screensnapr.com/e/l5YLW4.png[/rimg]
New feature is added! "Make Notes" check box is allow you to write some lines about your simulation settings, cookies, how bad HQ viewport of SI 2013 is or whatever. Just set a flag on it and click on "Cache" button. When you'll load cache again you will see your notes in the log of the script editor
Also PPG buttons have equivalent commands now so you can use them for hot keys. Python example: Application.QC_Cache()
And some bug fixes:
Now if you stop the cache procedure it will be loaded correctly
"Not Started" and "Ended" output ports of the "Retime Cache" compound are fixed
When you loading cache files of the object with the different frame ranges it will update the "Retime Cache" compound values now
bottleofram, you can check if plugin works in a workgroup (it should be now, but I don't know for sure)
Link is updated (now on dropbox again)
And some bug fixes:
Re: Quick Cache 2
oh, how about this viewtopic.php?f=19&t=2293 ;) not exactly a replacement for the cache on file node but an 'addition' also this is really crude and simple way to do this, nowhere near as elegant as Iamvfx's implementation but it gets the job done for slowing down (or speeding up) a cache without having to re-cache substeps.druitre wrote:I've got another question/feature request:
- bottleofram
Re: Quick Cache 2
Workgroup installation doesnt work yet, Constantine. Its looking for Capture.preset in the user folder (even if the capture is checked off), gives me an option to locate it manually but than it seems to fail completely (both cache and reading).
In any case, thanks for trying. Currently, i have no problem installing it in a regular user folder.
Re: Quick Cache 2
Oh, my bad, sorry! I forgot about it
Now it works! Thank you for helping me out, bottleofram!
Link is updated
Great compound, Tekano, thanks!
Link is updated
Users browsing this forum: No registered users and 27 guests
