hi guys,
I don't know what is missing, but the normal map doesn't work with wrapUV as in image show :
so any help
Normal map doesn't work with wrap UV
Re: Normal map doesn't work with wrap UV
Could be the texture repeats settings in the normal map properties
- KLONOA WORKS
I tried but doesn't work.rpmaguire wrote:Could be the texture repeats settings in the normal map properties
Tested this, same issue (Softimage 2013), the only quick solution I could find is to set the texture repeats on the XSINormalMap shader node instead of using the uv space warp.
Users browsing this forum: trendiction [Bot] and 27 guests
