SI only imports one UV texture via Alembic
Pancho
Post by Pancho » 17 Aug 2015, 17:12
Am I missing something or is this a bug or purpose. The UV textures created in Modo import fine into Houdini, but in SI I only see one of them. Guess I'm using the latest Exocortex version. Anybody with the same problem?
Tom
Pancho
Re: SI only imports one UV texture via Alembic
Post by Pancho » 17 Aug 2015, 17:15
It's Crate 1.1.145.
Pancho
Post by Pancho » 18 Aug 2015, 13:34
Is this working for everybody except me? Also tried to import an .abc from Houdini. Same problem. SI only lists one texture projection, while Houdini imported all three from Modo.
Do I need to transfer the context (vertex, point, primitive) of the UV maps in Houdini so that Crate can deal with them?
Post by Hirazi Blue » 18 Aug 2015, 13:53
You have probably tried this already, but I have to ask:
Do UV textures exported via the 2015 built-in Alembic importer suffer the same fate?
Users browsing this forum: trendiction [Bot] and 1 guest
