mod tool 6.01 on windows 7
Topics related to game developing
willardorwud
Post by willardorwud » 24 Jan 2017, 23:54
every time I try to install mod tool 6.01 on windows 7 I get a error saying the installer is corrupt now it worked fine when I had windows vista and I have tried redownloading it from mod db but it will not work
Draise
Skype: ondraise
Re: mod tool 6.01 on windows 7
Post by Draise » 25 Jan 2017, 05:33
Try Mod Tool 7.5, which may be more compatible. You can also get it on ModDB or even on Steam (I think).
Rork
Post by Rork » 25 Jan 2017, 15:43
Did you try by installing it with the 'compatibility mode'?
I'm very surprised it still worked though, 6.01 is quite old and with all the changes in Win7 it might be 'on the edge' of the OS support.
minilogoguy18
Post by minilogoguy18 » 31 Jan 2017, 00:16
That's really strange, I'm using Windows 10 and Mod Tool 6.01 installed fine. I also downloaded from ModDB, didn't use any compatibility settings unless Win10 did it automatically.
You should probably just use 7.5, the only thing I've found that 7.5 is missing is Model (EMDL) export, for some reason it's removed from 7.5.
willardorwud
Post by willardorwud » 04 Feb 2017, 12:47
I've tried compatibility mode for xp and vista but it will not work I want to use the valve source plugin for mod tool 6.01
minilogoguy18
Post by minilogoguy18 » 05 Feb 2017, 21:19
I know before that the valve source tools didn't work quite right with 7.5 but there hasn't been any update or fix for that?
Maybe if the source code is out there for the addon it could be fixed by someone.
willardorwud
Post by willardorwud » 06 Feb 2017, 21:04
this looks like a good fix
https://www.microsoft.com/en-gb/downloa ... px?id=8002
this is a windows xp mode for windows 7
trea
Post by trea » 29 Apr 2017, 02:01
Hi
The valve source addon will only work with 32-bit XSI versions, and the SMD and VMF dlls were compiled with XSI SDK 6.0 which is why those plugins fail. The last 32-bit release was XSI 2013. I have recompiled the valve source addon with the XSI 2013 SDK. I was unable to port it to x64 due to the libraries used. This is a quick fix so please tell me if there are any issues. The addon was compiled with Microsoft Visual Studio 2005 so if the plugins do not work download the require redistribute files for 2005 x86.
dowload from archive.org (update: recompiled HelperBoneOp.dll)
willardorwud
Post by willardorwud » 29 Apr 2017, 18:50
trea wrote:Hi
is it ok if I share these with the rest of the source modding community I will make sure you get all the credit just what do you want to be known by
trea
Post by trea » 29 Apr 2017, 23:02
No credit needed, I've done zero edits apart from updating the XSI SDK used. Please check the previous post I have updated it.
willardorwud
Post by willardorwud » 29 Apr 2017, 23:06
but you where the one who fixed it so credit to valve and you what do you want to be known bye in the credits .txt that will come with it
trea
Post by trea » 29 Apr 2017, 23:10
The author description is the same as the original 'Softimage'. I don't feel like I've made enough changes to be credited. It's still just as buggy as it was with modtools.
trea
Post by trea » 03 Jul 2018, 19:17
Apologies to double post but I figured I would share a fix for valve addon 6.02. This will fix the issues using rig from guide option when using mod tool 7.5. Replace the VBS script located at within the Addons\ValveSource\Application\Plugins\ directory. Download here.
