How rendering should be
Re: How rendering should be
Agree, but rumors (and some info is more than a simple rumor) talk about Maya development in two direction, videogame (project Skyline) and VFX (maya FX, due the name I guess is a VFX oriented project), also AD has the Excalibur project for 3dsm (exist more?). So they are not stationary (only in softimage side... no rumors, no "secret" project)
IMHO, they don't see in Houdini or Cinema a real menace for their businesses, their users base is consolidate so they can look to other market where competitor are more strong (videogame field? No one product in AD portfolio in this field (I mean something like Unreal Engine or Crisis)
I remember pretty clearly Ken Pimentel admitting how Cinema 4D was growing and kinda "treatening" 3ds max, and he said they were working to make max stronger.
The difference between AD and other software houses is simple. AD is unable to provide good updates in short time, so you have to wait years, other companies are more productive, fast, dedicated, and this is a winning key, most of this is because AD made a fuckin mess with their softwares, they didnt care since start so after all this time all the bugs, mess and things they had to fix before are coming out all of a sudden and all together.
I am always quite amused on how many people underestimate Modo or Cinema 4D, main because of their lazyness to try them out.
Then you have people saying "omg i tried to rig and animate in Cinema 4d and was a nightmare, that software is shit", well why dont you try to do Archviz and work with dwg in Softimage?
Cinema 4D is not made to compete with maya animation/rigging system, but give it time. Meaningwhile it just shines on all other departments, from pure graphic, to motion graphic, to advertising, product design, architecture, and even animation vfx. So yeah it quite seem like people are just too lazy to try it out.
Do a simple test, open c4d and import a 150mb hdri file and drag and drop it everywhere from shader diffuse to environment, and see how much time it takes to load, then do the same in Softimage. I can assure you there are countless of those performance/workflow things. Even more evident. You can see here the difference between a modern and well written application and another that is left untouch without updates and bugfixes.
You cant pretend to compete with modern things without update yourself to being modern. There is a moment where you will just fall back, happened to Mental Ray with Vray, and its gonna happen again, its just normal. AD is simply fucking up on every front.
It always depends and come down to what you need to do, but beside that there is a ground where the whole toolset (software) grows.
The ground cinema/houdini/modo has is way more modern, faster, intuitive, updated than Autodesk products. Which leads them to just have to add toolsets to compete fully with AD, while AD have a crap ground to work with and stack on top bought toolsets, producing a gigantic mess.
Starting from the workflow, the interface, the ease of use, the drag and drop system, the multi project options, there are a lot of things that just work out of the box in cinema/houdini/modo where in AD is just a fucking mess. When i look at the "whishlist" from softimage, most annoying things are about solid ground, things that werent fixed/updated since years. Workflow problems.
Interface, UI. You have always time to add a toolset or even buy and integrate a plugin, but what AD seems to not understand is they have to work on their ground, and this is what will make difference in a long run, because as you saw Cinema 4D had an awesome ground and they just keep adding tools on top of it without a single problem, same goes for modo and Houdini, and even Blender.
Time will tell, but i can already see whats happening, its quite clear.
the current max version is xbr. 2014 will be the end of xbr developement then the max core is rewritten/overwritten/whatever or lets say its the final step of xbr developement (which does not mean the developement stops). and yes, its a bit lame compared to the xbr idea video presentation some years ago. i think max is missing the studios input that maya has.Nizar wrote: also AD has the Excalibur project for 3dsm (exist more?)
cinema is not ready for high end work. as soon as you start to work with alot of data, textures are geometry, cinema is slow down alot. that slow that you switch back to max, maya or xsi. alot of deformer? forget the speed, its unusable not because it will be slow, also the ram usage is exploding. but cinema is not done for these kind of work. their customers dont need this, so its good placed on the market.Maximus wrote: I am always quite amused on how many people underestimate Modo or Cinema 4D, main because of their lazyness to try them out.
Actually no, Maya heavily used by the artists in gamedev industry for modelling and animation, custom engines are built for real-time rendering and custom game logics. Some VFX companies, for some unknown and weird reasons, still use Maya also. I guess they wrote a tons of their shit a long time ago and now can't change the pipelineNizar wrote:(videogame field? No one product in AD portfolio in this field (I mean something like Unreal Engine or Crisis)
Customize maya like sort of realtime engine ala crisis?iamVFX wrote:Actually no, Maya heavily used by the artists in gamedev industry for modelling and animation, custom engines are built for real-time rendering and custom game logics. Some VFX companies, for some unknown and weird reasons, still use Maya also. I guess they wrote a tons of their shit a long time ago and now can't change the pipelineNizar wrote:(videogame field? No one product in AD portfolio in this field (I mean something like Unreal Engine or Crisis)
So this is excalibur? Poor 3dsm...the current max version is xbr. 2014 will be the end of xbr developement then the max core is rewritten/overwritten/whatever or lets say its the final step of xbr developement (which does not mean the developement stops). and yes, its a bit lame compared to the xbr idea video presentation some years ago. i think max is missing the studios input that maya has.
Maximus@ I well know modo, I like it, rendering is so simple and intuitive, a real joy to work with but cannot substitute softimage strong and consolidate modelling tools (I found some annoying bugs in last release), and with simple scene lag too. In particular the workflow is a bit too slow in many area. Rigging and animation cannot be compared and I think, due how slowing they archive the actual CA, they cannot compete with the actual softimage feature before 3 or 5 years (or never, actually I studying facerobot and found it great).
Cannot say nothing about Cinema, only I see a very happy user base....
The software impressed me is blender, is incredible how fast they archive great result and in some area is very great (modelling is very fast and rigging is simple and effective). I wait the result of the last google summer of code (viewport FX (more fast and strong viewport perfomance), precision modelling tool (a set of new tools and snapping), dynamic retopology (sculpt like dynamesh), GUI improvment and some improvement on cycles side)
No, models, rigs and animations are exported to a custom engine that will just displays/blends them.Nizar wrote:Customize maya like sort of realtime engine ala crisis?
The situation around Maya is funny, because Autodesk want to please VFX and gamedev guys at the same time (and they'll fail, eventually, a bird in the hand is worth two in the bush), when Softimage could easily take a place in gamedev industry.
If you look at the old videos of Mark which shows some real-time features that was used by Valve during Half-Life 2 development or exporters for various engines (including CryEngine 2) in XSI Mod Tool, you can easily see how easy and natural the market could be achieved.
Maya 2013 will have DX11 viewport now. Do you ever ask yourself what's happened with DX10 feature in SI?
the mysterious AD plan...
Actually I reading some thread on Luxology board, about the last news on AD financial issue, one of the main subject concern how many time softimage will survive under AD, and if they will close it:
http://forums.luxology.com/topic.aspx?f=4&t=69412
I don't mean they have reason, I would like to stress how people outside AD and his fellow users base see softimage actual situation and future.
this policy of development of AD just help people migrate to other software
xsibase don't work, where i can post problems and wishes for tools
probably they add new tools only for personal use
Just look at forums Modo, Cinema, Blender you get answers to any questions from developers.
start learning Blender
I dont know where people draw the line between work and high end work, so might as well make me an example, because from studio i know, works i see cinema 4d is more than capable to cover a gigantic variety of jobs from simple to advanced.Kzin wrote:cinema is not ready for high end work. as soon as you start to work with alot of data, textures are geometry, cinema is slow down alot. that slow that you switch back to max, maya or xsi. alot of deformer? forget the speed, its unusable not because it will be slow, also the ram usage is exploding. but cinema is not done for these kind of work. their customers dont need this, so its good placed on the market.Maximus wrote: I am always quite amused on how many people underestimate Modo or Cinema 4D, main because of their lazyness to try them out.
Of course you wont see cinema 4d being used to rig King Kong at Weta digital. You know there are bilions of other markets and jobs other than that.
You know this looks to me the same topic there was time ago, "Vray is only for archviz", yeah go check it out now
- Hirazi Blue
Ah, the mythical mass migration away from Autodesk... The sad truth is that it will never happen! Users tend to be fiercely loyal towards the product they are familiar with and use in production. Not out of some kind of brand loyalty, but because they need this product to get the job done! In my experience, all the bitching and moaning on the different forums hardly ever seems to amount to many actually taking the plunge to adopt new software. Autodesk really hasn’t got anything to worry about in that respect. And should a product itself be killed, for instance if Autodesk eventually decides to kill Softimage (read it again: ”if”, not “when”!!!!) I am pretty certain, most Softimage users would take Autodesk up on a nice side-grade offer and would start to use Maya or Max, instead of looking elsewhere. They'd bitch and moan about it for a while, but they'd start using it nonetheless...Ramon wrote:this policy of development of AD just help people migrate to other software
Life is good for Mr. and Mrs. Autodesk... ;)
I'm not so sure about. If Cinema or what else will show some great feature/capability making easer our life why don't try?Hirazi Blue wrote:Ah, the mythical mass migration away from Autodesk... The sad truth is that it will never happen! Users tend to be fiercely loyal towards the product they are familiar with and use in production. Not out of some kind of brand loyalty, but because they need this product to get the job done! In my experience, all the bitching and moaning on the different forums hardly ever seems to amount to many actually taking the plunge to adopt new software. Autodesk really hasn’t got anything to worry about in that respect. And should a product itself be killed, for instance if Autodesk eventually decides to kill Softimage (read it again: ”if”, not “when”!!!!) I am pretty certain, most Softimage users would take Autodesk up on a nice side-grade offer and would start to use Maya or Max, instead of looking elsewhere. They'd bitch and moan about it for a while, but they'd start using it nonetheless...Ramon wrote:this policy of development of AD just help people migrate to other software
Learn an application is a big effort in terms of study, time and money, if a freelance (because who want work on the industry usually pick up maya or 3dsm wagon) will see all his effort wasted by AD choice, IMHO, why doing again some error? So will not waste its effort on AD side. With a bit of struggle every software out there can doing the job (more fast or more slow), so if I must learn another application I will prefer some no AD product.
it comes from my own experience (i know cinema since 1999). try it by yourself and you will see whats happen if you have to render alot of highres maps at the same time. or use alot of deformers, cinema is not responding. you have to disable all the deformers to make the whole thing workable again (editor speed and display is the problem). highres geo is also a big problem.Maximus wrote:I dont know where people draw the line between work and high end work, so might as well make me an example, because from studio i know, works i see cinema 4d is more than capable to cover a gigantic variety of jobs from simple to advanced.Kzin wrote:cinema is not ready for high end work. as soon as you start to work with alot of data, textures are geometry, cinema is slow down alot. that slow that you switch back to max, maya or xsi. alot of deformer? forget the speed, its unusable not because it will be slow, also the ram usage is exploding. but cinema is not done for these kind of work. their customers dont need this, so its good placed on the market.Maximus wrote: I am always quite amused on how many people underestimate Modo or Cinema 4D, main because of their lazyness to try them out.
i did not wrote its not good. its good for what its done and where it is placed on the market. but dont think its a competitor for max, xsi or maya. and i dont think maxon is going in this direction. it works great on their current market. the developement of the last ten years shows that they dont aim high end 3d market at all, but thats ok.
https://vimeo.com/47478043#at=0
https://www.caustic.com/gallery_movies_ ... h2012_Maya
https://vimeo.com/47960302
now how many of you would love a viewport like this? read everything, from shave&haircut to carpaing and paint effects..
we have the HQV
we have the HQV
I don't like HQV (cycles and modo (without disturbing GPU and with a preview very close to final render) are many steps forward IMO), but HQV is an half baked feature. I don't think, using the integrated mental ray, they can match the speed showed in this Caustic video, but can improve the quality in next release (High "Quality" Viewport is not a well guessed name)
Users browsing this forum: No registered users and 45 guests
