aaOcean open sourced...
aaOcean Suite
The Open Source aaOcean Suite is a collection of Softimage ICE nodes and a mental
ray shaders that implements Jerry Tessendorf's paper on simulating ocean waves, which
is currently the most widely used method for open water ocean surfacemodeling being
used in the industry.
This particular implementation presents itself as a 3D deforming grid inside Softimage, which then becomes the source of vector displacement map sequences that are sent to Mental Ray for final rendering. One of the benefits of using this approach is that it opens up the possibility of making other 3D objects inside Softimage react with the ocean grid via ICE. Another benefit is the speed that it brings in setting up your ocean right inside Softimage on a low resolution ocean grid to set basic paramters like wave height and speed, rather than rendering a sequence of images in Mental Ray. Works nicely in conjunction with Werner Ziemerink's Wave Curl.
local backup: aaocean.zip
author site: http://www.amaanakram.com / download: /?page_id=131 / si-community thread / repository @bitbucket.com
Re: aaOcean open sourced...
sorry about these issues. I'll check over the weekend and report back
Hi guys,
I just uploaded a new version, Rev079, to bitbucket
https://bitbucket.org/amaanakram/aaocean/downloads
Changelog:
-fixed shader defs not finding dll
-added ability to export ocean data as RGBA vector maps, object-space vector displacement in RGB, foam in alpha. This can be used to bake oceans into image sequences and then used with Mental Ray's own Vector Displacement shader. Arnold shader has the same ability.
Please let me know if you get any issues with this version
amaan
Changelog:
amaan
- bottleofram
Hi guys,
Does anyone know where can i download the newest version of aaOcean? BitBucket denies me an access to the repository Amaan has been linking.
Thanks in advance.
Thanks in advance.
You need to contact Amaan Akram and ask him nicely.
- bottleofram
Ok, thanks. Will do.SamHowell wrote:You need to contact Amaan Akram and ask him nicely.
- Hirazi Blue
So, after being sent to Bitbucket by Amaan Akram's website, registering there and after that being told that I still couldn't access the files, I would really like to know what's going on here. It feels like I've simply been tricked to register at Bitbucket. This seems to be a new interpretation of the concept of "open source" I wasn't previously aware of... If the files are only available "on demand", maybe mr. Akram should take down the Bitbucket link from his website.
Maybe the website is in autopilot mode.
I thought I was missing something after I registered, but it seems not. I emailed Amaan a week or two back, but haven't received a reply.
Not sure if it's the latest version, but I copied it from bitbucket back then so it's not that old
https://dl.dropbox.com/u/10965660/share ... Rev079.zip
Thanks a lot!
Could someone explain the steps needed to replace the version 1.7 with the new version? i can't find any addon in the 2.5 version
And are there any tuts available for the ice version?
This can be installed like this:geoath wrote:Thanks a lot!
Create a new folder "[user/workgroup path]/Addons/aaOcean" and copy the contents of both "Softimage" folders into it. The shader should be self registering so there's no need to manually register any dlls.
Can't answer how to migrate between the version, if that was what you meant
- bottleofram
Yeah, i'm a bit confused too. Like Sam suggested, i've sent Amaan an email and he was kind enough to send me what appears to be the latest version. The archive is called aaOcean2.6_deploy_Rev_204, however, it only contains deformer and shader dll's (no js, xsicompound etc.) with a note that it comes "as is with no support and installation help". I wasn't sure what to do with them so i moved away from it for the time being.Hirazi Blue wrote:So, after being sent to Bitbucket by Amaan Akram's website, registering there and after that being told that I still couldn't access the files, I would really like to know what's going on here. It feels like I've simply been tricked to register at Bitbucket. This seems to be a new interpretation of the concept of "open source" I wasn't previously aware of... If the files are only available "on demand", maybe mr. Akram should take down the Bitbucket link from his website.
Again, it's a little bit unclear whether this is an open or private project.
Hi all,
Apologies for the confusion in the download locations. I've been working flat out in a non-softimage studio and have found it difficult to support this plugin -- I get a lot of support emails and it is hard to keep up with them.
The current download link for the stable version is
http://www.amaanakram.com/plugins/aaOce ... ev_204.rar
This contains mental ray shaders and maya/xsi/houdini plugins and sample scenes. Arnold shaders are not distributed because of my NDA with solid angle. You may download them from the solid angle trac website. Please get in touch if you are having problems.
This is a fully-featured tessendorf implementation and does not suffer from the frequency-space sampling limitations of the houdini ocean toolkit implementations out there.
I'd greatly appreciate reporting the usage of this plugin back to me, assuming you find this plugin useful and use it on a production. This plugin is free and the only thing that keeps it afloat is user-feedback.
Thanks,
Amaan
Thanks,
Amaan
Thanks Amaan for the update.
Do you have the video of ocean tutorials? i really don't understand how to do that....
i hope you can show me....
Users browsing this forum: brandwatch [Bot] and 26 guests
