Page 1 of 1
Extrude Polygon Along Curve
Posted: 24 Dec 2011, 15:15
by Chris_TC
Since it was suggested several times, here's a test video.
This is based on the "Cable compound" whose construction I detailed in my bridge tutorial video part 2. However, it doesn't use any repeat nodes anymore, and I adapted it to work with an input polygon and curve.
There are still certain problems. The new geometry is currently a separate polygon island - it should of course be welded automatically. And there are some issues with orientation and upvectors. If I can't solve these (or don't have the time to), I'll post the unfinished compound for others to take a look. Or maybe someone else comes up with a fully working solution right away (Fabricio? :D )
Re: Extrude Polygon Along Curve
Posted: 24 Dec 2011, 16:02
by ActionArt
Nice! Would it be able to cap both ends automatically?
Posted: 24 Dec 2011, 16:18
by Chris_TC
ActionArt wrote:Nice! Would it be able to cap both ends automatically?
Capping the end is extremely simple, I just haven't added that yet. Adding control for scaling the thickness or twisting along the length is also quite easy.
I find that the main difficulty lies in maintaining a reasonable upvector. Currently, the extrusion can have some weird flips somewhere in the middle depending on the curve.
Posted: 24 Dec 2011, 22:54
by iamVFX
I make up vector of the curves by this way, maybe you find it useful. Null up vector prevents vector to be flipped when curve is rotated with it
Posted: 25 Dec 2011, 00:38
by Chris_TC
iamVFX wrote:I make up vector of the curves by this way, maybe you find it useful. Null up vector prevents vector to be flipped when curve is rotated with it
Very interesting, thank you!
So it appears that your magic lies in using a Euler to Rotation and a Rotate Vector. I don't know what exactly this does, but I'll use it on the compound and see if it solves the issues I've had.
Posted: 25 Dec 2011, 10:34
by iamVFX
I'm not sure how it works in this case too, but the fact is that if there will be some crazy rotations along the curve you'll just take a null and move it around to fix it... Not so elegant way I guess but if you want rotate a whole curve you just rotate it with null and there will be no change in polygons direction
Posted: 02 Jan 2012, 05:09
by fabricio.chamon
the way I do it (as suggested by Guillaume LaForge on the "Create Extrusion along Strands" compound) is to iterate over all curve points and calculate the current normal by rotating the previous normal. This makes every normal dependant on the previous segment, thus making them continuous.
Here's one image showing the math for 2nd point on the curve. Also the icetree.
I think the images will explain better than I could with words, but let me know if you have any problems.
and btw, nice job Chris!
Posted: 02 Jan 2012, 05:27
by fabricio.chamon
...oh, and here is a simple scene that I did to review some stuff. It is as simple as it can get (no optimizations, so expect lots of repeat nodes around). It focus on making the core extrusion functionality easily readable on the icetree.
Just in case you want to check the normal rotation logic...
Posted: 02 Jan 2012, 16:05
by Chris_TC
Thank you for the clear explanation! Your image shows well how the logic needs to work, so it shouldn't be too difficult to implement. Will report back :)
Posted: 12 Jan 2012, 21:03
by Hirazi Blue
@Chris_TC - If it takes longer to complete it, would it be possible for you to upload the incomplete version of the compound - the one you apparently based the video on - so I can take it apart in private and find out where exactly my own sorry attempt went horribly wrong?
Posted: 19 Jan 2012, 21:28
by Chris_TC
Sorry for taking so long to answer. I've only now had a chance to take another look at my compound. I implemented Fabricio's/Guillaume's awesome technique, and I think I got that right. But for some reason I've set it up such that I only get a good result when the input polygon is roughly facing the +Z axis* Something's definitely not right.
*This has nothing to do with Fabricio's technique by the way. I remember having this issue back when I first made the compound.
I don't know how soon I can get back to it, so here's the compound like you asked. Unfortunately, some of it is hard to read - I initally avoided Repeat nodes, which makes the logic much bigger. However, the Normals technique seems to require a repeat node, because each normal depends on the previous one.
Posted: 20 Jan 2012, 12:00
by Hirazi Blue
Thanks... :ymhug:
I will try to "decipher" it & that in itself will be a valuable learning experience I'm sure
Posted: 20 Jan 2012, 21:48
by Chris_TC
Sure thing. I recommend to look at each sub tree step by step. Unplug things and visualize values starting on the left. Then keep track of them and see how they change as you move to the right. That's how I'd decipher my own tree now if I had to.
Also, always try to work with simple objects. Instead of applying the compound on a mesh with 10,000 polygons and using a really long curve, I'd just use a cube and a linear 3-segment curve or something.
