Booleans with SubD surfaces - Impossible???
- cheeseburger
Re: Booleans with SubD surfaces - Impossible???
Surely we could have something like this. The edging and filleting available in other apps when doing Boolean has always made me green with envy !
Can you provide link to app that does filleting with subd surfaces after boolean?
- H -
- cheeseburger
Max used to, with the help of a really great plugin (I think it was Power Booleans by NPower), Modo now obviously and you can get a similar effect with Rhino, although that's using Nurbs etc. I'll go get a coffee and try and remember if there are some others ...
I know about NURBS, but never saw that on any subd program. I am using Modo, and boolean is not that powerfull at all.
- H -
- cheeseburger
What do you think of the video at the beginning of the thread ?... Looks pretty awsome
I think that's an add on
O yeah, that is Groboto tech. When it shows in Modo will judge it. It looks pretty impressive though.
- H -
- cheeseburger
Looks great
so simple and fast too
From what I could gather, MeshFusion could be described as "interactive CSG with auto beveling".
If that's so, you're dealing with a load of objects at once, and would need a very specific designed user interface to be able to work with that in a productive way. So ICE, maybe, but without the UI and interaction tools that come along with it, probably useless.
- cheeseburger
Yeah, a kind of Mootzoidy type of thing ...
p.s. Love your avatar
well... the resulting mesh is pretty good !!!
if you click on their bottom right gallery item here and look at the wires http://groboto.com/showgallery/
so, more or less, like Power Booleans for Max - and.... by courtesy of AD, Maya and Maya LT , tooNNois wrote:well... the resulting mesh is pretty good !!!
hummm, a very little more or less then ;-)Mathaeus wrote:so, more or less, like Power Booleans for Max - and.... by courtesy of AD, Maya and Maya LT , tooNNois wrote:well... the resulting mesh is pretty good !!!
If Power Booleans had user-definable bevels automatically generated between surfaces (which I'm pretty sure it doesn't).Mathaeus wrote:so, more or less, like Power Booleans for Max - and.... by courtesy of AD, Maya and Maya LT , tooNNois wrote:well... the resulting mesh is pretty good !!!
As far as I know, it doesn't. However, by taking the pictures of Groboto work. it seems that Power Boolean relies on much much stronger algorithm. Power Boolean tries to create only quads and triangles as output, usable for subdividing later. Groboto seems to do just the cut on subdivided mesh, where some cuts looks like a good candidate, to be interpreted as non manifold in Renderman compliant renderers, for example.reberhart wrote:Mathaeus wrote:
After all, if someone wants, really no big deal to add these user defined level to Power Booleans.
In practice, no one of two has examples of quality, even close to examples of NURBS modeling through the decades - let's say, like this one, created in MoI, which is 'light' variance of Rhino - you get it for 300 bucks.
I intentionally said 'more or less', trying to be benevolent to yet another nice workflow trick, based on "cheaper than usual" tech, just like the everything in Modo. Except the renderer.
Just personally, if this is all of modeling for Modo 801, I'll get MoI, instead of Modo upgrade.
Users browsing this forum: No registered users and 40 guests
