some xsi specific fixes on versions > 2.0
[XSI] Added Redshift_ApplyMaterialID command
[XSI] Fixed bug that would ignore the texture filtering property overrides on normal, environment and camera map map shaders
[XSI] Added initial support for RenderMap baking
[XSI] Fixed bug that would prevent blending of RS Skin materials (bug introduced in 2.0.11)
[XSI] Fixed bug that would produce crashes during baking with multiple GPUs
[XSI] Modified (and hopefully fixed) code that was producing a crash during baking. More info here:
https://www.redshift3d.com/forums/viewthread/6134/
[XSI] Fixed bug that prevented certain Matte options from being correctly set on strands and hair
[XSI] Fixed bug that resulted in a script error when attempting to assign a new Redshift material to a partition on a non-active pass using the Render > Get > Material menu
[XSI] Fixed bug that caused incorrect channel naming when more than 1 Depth AOV was present
[XSI] Fixed compiler related bug that could cause point-cloud GI to not be generated for native Softimage material nodes
[XSI] Fixed error message “The parameter ‘ss_amount=’ does not exist on the Redshift Skin…”
