Headus is great..but its the only software I know that _forces_ you to learn keyboard shortcuts otherwise you cant do shitLukesmith123 wrote:Yeah I haven't used Softimage for a couple of years, I would have killed for the unfold feature back then.
I tried Headus but I found the Interface and controls a nightmare!
UV Unwrapping
Re: UV Unwrapping
Re: UV Unwrapping
most probably you have two or more set of Uvs and when minimizing one of the other UV sets override the current one. Try deleting other sets.Can someone tell me how to save the unfolded UVs so that they export with the model? I currently have the UVs unwrapped the way I want them, but when I minimize the Texture Editor the texture reverts back to the original projection. I can get the UV arrangement back by selecting "UVs > Unfold" in the Texture Editor.
Re: UV Unwrapping
Thanks gaboraa, I think that was the problem. Got it working correctly now!
- KLONOA WORKS
Re: UV Unwrapping
I don't want to add topic for one question.
my question is there a way if I move the edge or point the uv doesn't broke ?
- KLONOA WORKS
Re: UV Unwrapping
mmm is there away without plugin
I saw this video
http://www.youtube.com/watch?v=ZcHPY9YidmI
I do the same but not working, is there something missing
I saw this video
Re: UV Unwrapping
The addon gaboraa has posted works only in 2012 and later I think, and it needs you to specify manually your UV if it's name isn't the default Texture_Coordinates_AUTO.
Open your context menu in your 3D View port, and look for "Apply Swimming Texture".
If you want a non ICE, very slow, but usable in pre2012 versions, you can use Gator.
Duplicate your object A (creating an obj B), Gator objA to objB, move Gator Operator above Modeling stack and apply transfer UV.
I wrote an script to do this for me:
https://dc582.4shared.com/download/Zg1z ... serveUV.js
Note: Since it is very slow with viewport on Textured I changed the texture resolution when the preserve tool is active. (Still, it is slow, so you may want to change your viewport to shaded)
M.Yara
- KLONOA WORKS
Re: UV Unwrapping
gaboraamyara wrote:The addon gaboraa has posted works only in 2012 and later I think, and it needs you to specify manually your UV if it's name isn't the default Texture_Coordinates_AUTO.
Thanks a lot I thought I need to move to Ice tree etc... I never use Ice tree until now xD.
now I get it thanks
mayara
seem the Gator interesting me but I didn't understand it .
apply transfer UV ? what do you mean of that.
http://softimage.wiki.softimage.com/index.php?title=Swimming_explicit_UVs
xD anyone explain this,Duplicate the original geometry then GATOR the UVs from the original onto the current geometry; leave GATOR live and select HIDE inputs on the GATOR dialog. Now move the GATOR operator up into the shape modeling region of the stack.
In the Image shader make sure you're using the GATOR UV property If the GATOR'd texture projection property has the same name as the original then rename to something like Texture_Projection1_GATOR then you should see 2 properties in the texture projection combo box.
Now you can model and swim the UVs.
Re: UV Unwrapping
Click the button "Transfer" under Materials, UVs, etc inside the Gator PPG.KLONOA WORKS wrote:apply transfer UV ? what do you mean of that.
BTW, the script I posted is a simple script, not a plugin. Run it from your Script Editor, or drag & drop it in a toolbar or shelf.
M.Yara
Users browsing this forum: No registered users and 52 guests
