Sorry, I should emphasize again: you have to key the frame again after you MMB+drag. Meaning I press K after MMB+dragging a frame to where I want it. This will work regardless of any existing keyframe on that frame, it will be replaced.druitre wrote:Hi Sonictk, if in your example you grab the key at frame 54 and drag it to frame 100, what do you get? I always get a no-go; the key at fr 100 remains. I think that is what people here are asking about - drag-replace keys. In the dopesheet it works, not in the timeline.
BTW, I too think it would be good if we were able to place keyframe copypasteactions under fast keyboard shortcuts. Haven't found a script or plug to do this yet.
Also you can copy/paste keys using shortcuts from the graph editor, I guess as a workaround. I never manipulate keys on the timeline as a general rule of thumb anyway, I usually stick to the graph editor for that. Maya habit ;X
