I do not know how to export (in a spreadsheet) the orientations of each point that makes up a curve (especially a linear curve, which can be found at Create>Curve>Linear Curve).
I've tried exporting the curve with Crosswalk but that didn't work.
I've also tried to set a random object (e.g. a cube) along the path of the curve, and exported that as an animation, but that didn't work either.
One way to solve this is by setting a random object on a trajectory of the curve, but I can't find the options to make the trajectory "Linear" and "Tangent" (which are the options that come up when you Set Path --> "Animate">"Path">"Set Path")
Thanks in advance.
Exporting the orientations of the points that make upa curve
