quickinset
QuickInset
Updated May 2013 (info) — Rewrite of the original QuickExtrude tool. This tool performs quick modo-like
interactive extrude, bevel and inset operations without showing a property page. Piotrek's
notes from the si-community thread: Extruding along normal is available only in 2012 SAP
for operations that relies on SI units you drag in component's normal direction,
for other ops (like point skirting ratio/bevel subdivisions) just drag across screen
subdivision highlighting is supported only for level 1 and only catmull-clark
J, L hotkeys change subdivision on extrude K hotkey is for repeating operation on highlighted component/subselection ENTER shows op PPG shift makes operations 10x slower
LMB is extruding, LMB and then RMB - changes inset ratio of extrusion MMB is beveling, , MMB and then RMB - changes bevel subdivisions RMB is insetting tool can also work in supra mode if you hotkey the tool
I've used it to model few production objects and it's pretty useful.
Developed with the interactive tool SDK. See Piotrek's video for a quick introduction
local backup: quickextrude_0.2.xsiaddon (June 2013) pmQuickExtrude2012.xsiaddon (older but SI 2012 compatible version) quickextrude_src.rar
quickinset
Tool was rewritten few times, so please report bugs...
- Extruding along normal is available only in 2012 SAP
- for operations that relies on SI units you drag in component's normal direction, for other ops (like point skirting ratio/bevel subdivisions) just drag across screen
- subdivision highlighting is supported only for level 1 and only catmull-clark
- J, L hotkeys change subdivision on extrude
- K hotkey is for repeating operation on highlighted component/subselection
- ENTER shows op PPG
- shift makes operations 10x slower
- LMB is extruding, LMB and then RMB - changes inset ratio of extrusion
- MMB is beveling, , MMB and then RMB - changes bevel subdivisions
- RMB is insetting
- tool can also work in supra mode if you hotkey the tool
- I've used it to model few production objects and it's pretty useful
- RMB is insetting
- quickextrude_0.2.zip
- ******** LATEST ******
xsiaddon, 64bit - (56.95 KiB) Downloaded 648 times
- quickextrude_src.rar
- source code
- (18.49 KiB) Downloaded 719 times
- pmQuickExtrude.zip
- xsiaddon, 2012 32/64bit
- (109.36 KiB) Downloaded 1151 times
Re: C++ custom tool SDK programming tip
WOW!!
That's what Softimage needs, interactive extrude and quick tools like your hybrid.
Oh, and I love poly highlighting!
Now if you could throw in edge bevel/extrude into same tool it would be killer.
Do you use modifiers, or just mouse buttons?
Please proceed.
Please proceed.
Right now I only use left/middle mouse button (repeat last extrude) and TAB to switch between extrude/inset mode.
- bottleofram
That is indeed an impressive tool, Piotrek. The reason why i always liked silo (and im sure it applies to other well known modelers) is it combines as many operation into one tool as possible. Quite a fewer hotkeys would be needed if the modeling tools in xsi were designed this way...
thanks, It is more a training tool to get familiar with c++ after 15 years of not using it. hopefully things will go faster now cause this tool took me 3 long days to get done.
That's great, it means you can make 100 tools per year!
Looks great...
Is this more of a "proof of concept", an "inhouse tool" or do you plan to release it someday?
Re: quickinset
mostly for learning, I plan to do more and will be sharing this as soon as possible.
Re: quickinset
gr8 origin!
Possible to show value numbers of insets and extrude?
Re: quickinset
uploaded new video with point and edge working and spacebar as inset/skirting ratio mod while extruding
ramon: yes definitly
Re: quickinset
You are nailing it Piotrek! Really exciting stuff.
Love the purple highlight color.
Will you release the code with the tools?
Thanks.
Thanks.
Re: quickinset
cool tool
I'm still undecided if I'd prefere a big number of new tools that do a small number of things, or vice-versa xD
Re: quickinset
OK here's "release candidate", let me know if it's working for you, suggestions are welcome!
x64 only as .xsiaddon
menu modify->Quick Inset or run command pmQuickInset()
this help is displayed in status bar:
tab - switch between inset and extrude mode
hold SPACE when extruding to adjust inset (bevel)
hold SHIFT to do 0.1 increments when extruding/insetting
middle mouse button = repeat last op
enter - show last op PPG
Please do not learn from my c++ code...
- quickinset_src.zip
- source code
- (10.45 KiB) Downloaded 457 times
- QuickInset.zip
- xsiaddon
- (18.5 KiB) Downloaded 659 times
Re: quickinset
thanks for sharing the code, i hope it encourages more programmers/TDs to develop using the new sdk.
