Did couple of quick tests. Everything seems to be working.SreckoM wrote:Can someone confirm that this works in SI 2012?
I am constantly getting Warning:Object error.
CurveTools
keyvis Curve Tools
V1.4. A set of curve-related tools with the recent addition of a curve tool panel
PPG. From the download page:
This addon adds the most needed Curve Operators to Softimage, bringing it to a level of flexibility comparable to 3ds max. It does not make Softimage an »industrial strength« Curve modeller, like e.g. Rhino, but in many scenarios you won't need another application for Curve editing any more. Tools included: Attach Curves: attach one or many Curve(Lists) to the first in the selection. Blend Subcurves: connect Subcurves with a Segment (bridge) between every selected Curve Boundary pair. Delete Subcurves: delete one or many Subcurves. Duplicate Subcurves: duplicate one or many Subcurves, with Translate x, y, z parameters. Extract All Subcurves: »explode« a CurveList - every Subcurve becomes a Curve object. Invert (Sub)Curves: change curve direction. Like the factory tool, but with Subcurve support. Log Curve Data: for debugging purposes. Logs (Sub)Curve details in a Script Editor. Points, Knot vector, degree, etc. Merge Subcurves: connect Subcurves by »welding« selected Boundary pairs (2 endpoints -> 1 midpoint). Offset (Sub)Curves: draw an outline around selected (Sub)Curves. Open/Close (Sub)Curves: like the factory tool, but with a few more options and with Subcurve support. Scissor Knots/Isopoints: cut Subcurve(s) in two or more pieces at selected Knots or Isopoints. Curve Tools Panel: Custom PPG containing all Curve Tools plus options for Isopoint selection: Intersections and Subdivisions. Curve trims and booleans can be realized with it (although maybe not as comfortable as in 3ds max).
After installation, all operators can be found under Model > Modify > Curve, except »Extract All Subcurves«, which is in Model > Create > Curve
Related plugins: Power Extrude, TinyCurveExtrude, MX Loft, Custom Loft, KP CurveTools, ICE Rope Rig
local backup: keyvisCurveTools v1.4.xsiaddon
author site: http://keyvis.at / download: ..Softimage/curve-tools/ / xsi-forum.de thread (german) / si-community thread
- bottleofram
Re: CurveTools
Re: CurveTools
Hmmm, unfortunately nothing works for me except Duplicate subcurves ...
BTW does anyone by any chance have Offset curve script from Helgee?
- H -
Re: CurveTools
Do you get any error messages, when executing the commands that don't work?
A little more info as to what's going wrong might help us to attempt to figure out how to possibly fix it...
Re: CurveTools
As I said several posts above I am getting only this message - 'Warning:Object error.'
- H -
Re: CurveTools
Sorry, I forgot...
Is that the full text of the error?
I will have to get back to you...
BTW - I did a search for the curveoffset tool,
but haven't been able to locate any working download/mirror...
(will check my own archives tomorrow!)
Re: CurveTools
here it is
' | Curve-Offset-Script |
' | @AUTHOR: HELGE MATHEE |
' | @VERSION: 1.0, 07-05-2003 |
' | www.mindthink.de/ohm |
' | copyright by Helge Mathee 2003 |
' never change the lines above, because they are
' generated automatically.
' To read the code in a well-formatted way, use a
' screen resolution of 1280x1024 mininum and
' Code Edit (http://jimmy_reumuth.tripod.com/)
' MAIN PART
ActivateObjectSelTool
for each sel in selection
set obj = sel
if sel.type = "crvlist" then
set objgeo = obj.activeprimitive.geometry
set points = objgeo.points
set p = xsimath.createvector3
set ve = xsimath.createvector3
normals = points.normalarray
dim amount,linear,merge,close,valid
closed = objgeo.closed
if closed then
GetParams2 amount,linear,valid
close = true
merge = false
else
GetParams amount,linear,merge,close,valid
end if
if valid then
if not merge then
on error resume next
DeleteObj obj.name&"_offset_"&int(amount)
on error goto 0
if linear then
SICreateCurve obj.name&"_offset_"&int(amount), 1, 1
else
SICreateCurve obj.name&"_offset_"&int(amount), 3, 1
end if
curvename = obj.name&"_offset_"&int(amount)
else
end if
for i = 0 to points.count-1
set ve = getNormal(i,points,normals,amount,closed)
if i>0 then
set ve = correctNormal(points.item(i-1).position,oldve,points.item(i).position,ve)
if ve.length = 0 then
set ve = oldve
end if
end if
set oldve = ve
p.add points.item(i).position,ve
SIAddPointOnCurveAtStart curvename,p.x,p.y,p.z, False
next
if close then
ApplyTopoOp "CrvOpenClose", curvename, 3, siPersistentOperation
end if
end if
else
logmessage "Select a crvlist"
end if
next
function getNormal(i,points,normals,amount,closed)
dim ve,p,p1,p2
if i = 0 then
if closed then
set p = points.item(i).position
set p1 = points.item(points.count-1).position
set p2 = points.item(i+1).position
p1.sub p,p1
p2.sub p,p2
p1.normalize p1
p2.normalize p2
ve.add p1,p2
ve.normalize ve
ve.scale amount/(sin(p1.angle(p2)/2)),ve
else
ve.x = normals(0,0)
ve.y = normals(1,0)
ve.z = normals(2,0)
ve.scale amount,ve
end if
elseif i = points.count-1 then
if closed then
set p1 = points.item(i-1).position
set p2 = points.item(0).position
p1.sub p1,p
p2.sub p2,p
p1.normalize p1
p2.normalize p2
ve.add p1,p2
ve.normalize ve
else
ve.x = normals(0,points.count-1)
ve.y = normals(1,points.count-1)
ve.z = normals(2,points.count-1)
ve.scale amount,ve
end if
else
p1.sub p,p1
p2.sub p,p2
p1.normalize p1
p2.normalize p2
ve.add p1,p2
ve.normalize ve
end if
set getNormal = ve
end function
function correctNormal(p1,r1,p2,r2)
dim vp,vt,t1,t2,v,tolerance
tolerance = 0.001
set t1 = xsimath.createvector3
set t2 = xsimath.createvector3
set vp = xsimath.createvector3
set vt = xsimath.createvector3
set v = xsimath.createvector3
t1.add p1,r1
t2.add p2,r2
vp.sub p2,p1
vt.sub t2,t1
vp.normalize vp
vt.normalize vt
if abs(abs(vp.x)-abs(vt.x))<tolerance and _
abs(abs(vp.y)-abs(vt.y))<tolerance and _
abs(abs(vp.z)-abs(vt.z))<tolerance then
v.copy r2
else
v.negate r2
end if
set correctNormal = v
end function
Function GetParams(amount,linear,merge,close,valid)
Dim oDial, OptionSliders
Valid = False
set oRoot = application.activeproject.activescene.root
Set oDial = AddProp("Custom_parameter_list", oRoot, , "CurveOffSet_Options").Value("Value")
OptionSliders = oRoot & "." & oDial
SIAddCustomParameter OptionSliders, "offset", siFloat, 1, -100, 100,, siPersistable+siSilent , -5, 5,, "offset"
SIAddCustomParameter OptionSliders, "linear", siBool, 1, 0.000, 1.000,, siPersistable+siSilent, 0.000, 1.000,, "Linear"
SIAddCustomParameter OptionSliders, "merge", siBool, 0, 0.000, 1.000,, siPersistable+siSilent, 0.000, 1.000,, "Merge"
SIAddCustomParameter OptionSliders, "close", siBool, 0, 0.000, 1.000,, siPersistable+siSilent, 0.000, 1.000,, "Close"
On Error Resume Next
InspectObj OptionSliders ,,"CurveOffset, copyright by Helge Mathee 2003",SIModal
If Err.Number <> 0 Then
DeleteObj OptionSliders
Exit Function
End If
amount = GetValue(OptionSliders & ".offset")
linear = GetValue(OptionSliders & ".linear")
merge = GetValue(OptionSliders & ".merge")
close = GetValue(OptionSliders & ".close")
Valid = True
End Function
Function GetParams2(amount,linear,valid)
Valid = False
Exit Function
End If
Valid = True
End Function
Re: CurveTools
I've spent some time trying to reproduce your error message and at one point I did. This was something however I myself could not reproduce afterwards, so it isn't really helpful, sorry. My guess would be that it has something to do with (the lack of documentation on) the selection criteria. Or it could be the object you're throwing at it.
But again, I can't say anything conclusive.
Maybe someone else can step up and provide some further insight...
Re: CurveTools
There has been an update to the CurveTools (now at version 1.1)
Quick and dirty translation of the only specifically mentioned change
(from the announcement @the German Softimage Community)
Video is apparently on its way (still...)New: SplitSubcurves not only accepts knots but also isopoints as inputs. One can now cut at any desired position.
Note: obviously one can select as many knots/isopoints as one likes (but only either knots or isopoints at one time)
Re: CurveTools
for all getting the object error warining. turning on and off the Immed mode will fix the problem. Softimage has to set a prefernece value for this. if you never used the script cant find this value and gives you an error.
Re: CurveTools
Just noticed, version 1.31 has been uploaded today: product page
Re: CurveTools
Thanks for the notice! I love these tools.
Re: CurveTools
Version 1.4 has been uploaded: get it here
From the changelog:
From the changelog:
;)v1.4:
Fixed: Bug in CurveToolsPanel – names of Curves inside Models are correctly stored now.
Added: NurbsRectangle Primitive. Params: Length, Width, Subdivs U, Subdivs V, Degree, Centered.
Added: NurbsNGon Primitive. Params: Radius, Sides, Initial Angle, Inscribed/Circumscribed.
Re: CurveTools
This is really awesome! All the necessary tools are there and I wish all of these were built in but as long as they are working, there is no problem:)
