It is currently 21 May 2013, 05:49
Post new topic Reply to topic  [ 112 posts ]  Go to page 1, 2, 3, 4, 5 ... 12  Next
 Post subject: quickPrimitive
PostPosted: 14 Feb 2012, 02:06
Uploaded v0.93
- you can now create light primitives
- some new preferences
File comment: NEW
quickprimitive_093.zip [375.33 KiB]
Downloaded 261 times
Uploaded v0.91
NEW: Preferences: Plane helper size, axis helper size, default subdivision for all primitives, option for creating UVs, option for 2 methods of creating cube/grid prim
NEW: Free cube drawing (uses scale!)
NEW: Draw cube/cone/cylinder in both directions (downwards/upwards to axis)
NEW: Tool scope buttons. Work on grid/selection/everything.
NEW: Autocreate texture projections (you can disable it in preferences)
NEW: Merge button. Merges primitives (or last prim if you shift+click) to selected mesh.
NEW: accurate snapping for "height" objects. So e.g. you can create cylinder between two faces.
FIX: Cube drawing
FIX: repeat last primitive (undo issue, subd. issues)
FIX: Wacom issues
FIX: snapping
FIX: subd. surface raycast bug
FIX: losing hotkeys
Hotkeys:
ENTER - show primitive PPG
(Shift+) J,K,L - change primitive subdivions
Now about merge button. It uses XSI Merge op. So you will loose all animation on selected mesh! I think also there is some bug in SAP because you will get some weird warning about autofixing clusters (doesn't happen in 2012 sp1)
Step by step what happens after you click merge (old mesh = selected object):
1. It runs merge command. New object is created.
2. It transfers all properties from old object to new object.
3. Changes new object name to old object name
4. Reconnects all children of old object to new object
5. Parents new object to old object's parent
Hello guys,
Here's new tool for primitive creation, >2012, x64 xsiaddon attached.
Tested on only 2 computers, so please reports bugs (and suggestions)
Quote:
v0.9
interactive primitive drawing. By default it's drawing prim "in front of camera". If you want to draw onto grid, turn on grid snapping and turn on snap (or hold ctrlkey) before drawing.
Supports curve, nurbsmesh, polymesh (full frame) and grid aligning (x/y/z axis as up vector)
ISSUES:
- skew scaled objects will give bad aligning. I wont fix this tho...
TODO:
-merge to selected mesh button
-diffrent drawing mode for all prims (like grid, from left to right corner)
-right now height of objects (cylinder, torus,cone...) is obtained by holding RMB after LMB drawing.
File comment: v093 source
quickPrimitive_0_93_source.7z [202.55 KiB]
Downloaded 83 times
File comment: UPDATE 1. 2012 x64 xsiaddon
pmQuickPrimitive_v_091_2012x64_addon.7z [238.2 KiB]
Downloaded 805 times
File comment: 2012 x64 xsiaddon
pmQuickPrimitive_2012_x64_addon.rar [247.36 KiB]
Downloaded 841 times
 Post subject: Re: quickPrimitive
PostPosted: 14 Feb 2012, 02:17
You are on the roll Piotrek! Really making use of those custom tools SDK.
Wow, nice stuff coming out of your lab.
edit: after actually watching the video all I can say is ...FANTASTIC ! :ymapplause:
PostPosted: 14 Feb 2012, 02:19
Online
this is just fantastic o.O
Thanks a lot for this tool, really great to have such interaction into softimage, i missed this...
So far no issues, i'll keep using it!
Max
PostPosted: 14 Feb 2012, 02:25
Thanks guys.
Forgot to mention, if it doesn't work for you please install this: http://www.microsoft.com/download/en/details.aspx?id=14632
Also, I've implemented my 'patch' for faster component highlighting (way faster than tweak tool).
But I've tested it only on my computer, so I would love to hear if it's also highlighting components (especially polys) faster on your machines.
PostPosted: 14 Feb 2012, 02:53
It seems highlighting is working faster than the tweak tool's one,
your gizmo detects polygons faster than Tweak Tool, and doesn't skip on them either.
PostPosted: 14 Feb 2012, 03:13
Suggestion:
Maybe implement height (RMB) in Grid creation operation, so that user can draw custom nonuniform box shape.Or figure out nonuniform creation/drawing.
I figured J,K,L buttons DO change subdivisions, MMB button is "repeat last". Maybe you should put these shortcuts in description.
Also it could be useful if subdivision could be changed while holding J,K,L and dragging, so it doesn't just subdivide one way/ increasing.
PostPosted: 14 Feb 2012, 08:41
Box primitive (length/width/height) is on my list. Problem is, there is no custom primitive class in sdk.There are some workarounds and I will look into it.
As for subdiving down you can hold SHIFT + J,K,L to decrease subdivs. I was thinking also about small on-screen input boxes where you can type subdivision levels.
PostPosted: 14 Feb 2012, 09:45
Would be nice to be able to change the size of the yellow plane as well.
Eric Thivierge
ethivierge@gmail.com
http://www.ethivierge.com
http://www.exocortex.com/products/species/
PostPosted: 14 Feb 2012, 11:47
I'd love to see CMIVFX doing a tutorial ,with you, on making such useful interactive tools.
PostPosted: 14 Feb 2012, 12:30
Wow. Thanks. This will be super useful
