Tentacle/Snake-ish rigg ?
pimeto
Post by pimeto » 05 Jul 2012, 22:46
Ok Ok, im really going nuts here. I have absolutely no experience with animation, riggin etc.
So i read and read but it seems i can't find the proper info i need to make this rigg that i want.
Ok ok, here is a pic of the object that i need to rig.
This is some monster that i made, the client insist that i should do the animation and rigging, because he is a cheap motherfoker ... But never mind this, i gotta make it...
So, i try the simple solutions that come with XSi - Create spine, create Tail etc... but they dont work as i need them.
I managed to rig it with Tail, but this thing is kinda simulated ? And i just can't figure out how to put some control point's where i need them to animate this rig.
The spine just dont behave like i want it to. It has 2 control points and its a pain in the ass/ impossible for me to create this snake-ish motion.
So what i need is something like this on the picture - a couple of bones and controllers (in the red). So when i move the controlers i get this smooth chain movement, like for example in the Spine rig that comes with XSI.
I feel like its a simple rig ??? Am i right ? Please someone, give some info/tutorials/ or just explain how to do this.
pimeto
Re: Tentacle/Snake-ish rigg ?
Post by pimeto » 05 Jul 2012, 22:51
I found this tutorial, made back in 1912....http://www.youtube.com/watch?v=1TLchsw9ty8
But seriously, i can't understand what and why this guy does but making so many different Nulls
Please, help guys! :)
AceMastermind
Post by AceMastermind » 06 Jul 2012, 04:09
I'm not an expert on what you're trying to do but you could give MT_spring a try.
mt_spring.zip
(4.83 KiB) Downloaded 114 times
mattmos
Post by mattmos » 06 Jul 2012, 07:26
If you draw a curve with 4 or 5 points along the length of the limb you want to move, you can use a couple of options under the animate/create/skeleton menu
First create chain from curve - small number of bones (to match number of points in curve). Don't constrain to curve.
Second create control spline - high number of divisions.
The parent the light green diamonds to the nearest bones, and animate the bones in FK, you will get a spread along the length of the curve. If you want to get more detailed you can animate the position of the green diamonds on top of the bones.
pimeto
Post by pimeto » 06 Jul 2012, 20:48
Well, i found this scrip over at some closed long time ago thread in Cgtalk.
It works really well for me... i managed to do the animation at a satisfaction level :)
Thanks guys, for the replys and help!
set oSelList = GetValue("SelectionList")
 set oItem = oSelList(0)
 strStringedSel = oItem
 set oGeometry = oItem.obj
 oNumberOf0DGeometries = oGeometry.Nb0D
 SetUserPref "SI3D_CONSTRAINT_COMPENSATION_MODE", 1
 for i=0 to (oNumberOf0DGeometries -1)
 set PrevNull = GetValue("SelectionList")
 CreateClusterCenterWithNull strStringedSel & ".pnt" & "[" & i & "]"
 if i>0 then
 set CurNull = GetValue("SelectionList")
 ApplyCns "Distance",CurNull ,PrevNull , true
 end if
 next
 SetUserPref "SI3D_CONSTRAINT_COMPENSATION_MODE", 0
 '_________________________________________________'
 ''''Change the variable below to change the number of bones'''''
 NumberOfbones = 5
 CreateChainfromCurve oItem, NumberOfBones , True
AceMastermind
Post by AceMastermind » 06 Jul 2012, 23:38
Here's a link to the source in case folks want more details:
http://forums.cgsociety.org/showpost.ph ... ostcount=5
wmendez also mentions in that thread using Isner Spine as alternative.
http://www.isner.com/isnerspine/spine_introduction.htm
Boris
Post by Boris » 22 Jul 2012, 20:44
Oops ,something went wrong :D
Boris
Post by Boris » 22 Jul 2012, 20:55
Thank you for sharing !
Users browsing this forum: brandwatch [Bot] and 23 guests
