Here is a simple compound that I have been playing with last few days. I hope that someone will find it interesting.
It creates evenly distributed particles along each axis inside of a geometry volume. It can use object texture or have its own color. Objects must have a texture map property created for texture to work.
I tried using it on some character models and I got interesting results. On animated characters it seams to be a little unstable. Sometimes it crashes softimage, sometimes not. Also it slows down down as you start increasing number of particles per axis.
I am not sure if someone already posted something like this, but it was fun to do and it was nice learning experience.
In archive there is compound and a simple test scene. It is a SI 2010 scene.
This is a result of that scene:
createParticlesFromGeometryVolume compound
- comp.rar
- (206.65 KiB) Downloaded 823 times
Re: createParticlesFromGeometryVolume compound
looks interesting.
I would like to try it...but i do not have SI 2010...only 7.01.
Would you mind sharing the compound by itself?
In the archive I uploaded in my first post there is also a compound.
It seems that this compound doesn't work under 7.01
Maybe the problem with "repeat with counter" compound?
I haven't checked this myself, but I assume the "repeat with counter" probably is the one included in Phil's ICE Pack, which, AFAIK, should work in 7.01 also.
Yes the "repeat with counter" is used from Phil's pack. I don't have 7.01 around me anywhere so can't test it. I tried it in 7.5 now and it works after I install the Phil's Pack.
