The Measuring Tool Thread
Fast Launcher
A plugin from around 2013 This plugin lets you start any document or program from inside Softimage. It has a
simple configuration file in which you can simple add/remove the menu entries. The
Plugin will run on Softimage 2012 x64 and above.
local backup:launcher.xsiaddon
For details see Fast Launcher for Softimage and Fast Launcher for Softimage: The next step.
Basic Measure Tool
The Basic Measure Tool measures the length of a line segment or a series of line segments.
In an alternative mode (middle mouse button to toggle), it measures the angle between
two lines. This is a custom tool working fully interactively with snapping to points/grids/etc.
and without changing the scene.
local backup: BasicRuler.xsiaddon
Zoltán Ócsai shows a preview video of his upcoming nifty looking measuring tool:
kCS IceRuler 0.9 - Measuring Tool for Softimage
Re: Soon? kCS IceRuler 0.9 - Measuring Tool
</regulator breathing on>
The ICE is strong in this one.........
</ regulator breathing off> ;)
Very impressive tool, and ICE tree. LOL!
This will be very useful for a lot of tasks, can't wait to testdrive!
- wireframex
This is a tool that miss me a lot in SI.
Thank for your work
Thank for your work
Impressive...most impressive...
Meanwhile Stephan Woermann seems to be working
on his own - as yet unreleased - measuring tool...
are we sharing measuring tools here? i made this one a while ago...
list of measurements taken...
unit conversion...
multi line measuring...
it also does this cool thing where your measurement is copied to the clipboard for pasting. i have been meaning to do more with it, especially a protractor tool like zoltan has done. but i just haven't had time, but its open source and free for other to extend.
source code...
https://github.com/caron/TapeMeasure
download plugin...
https://github.com/caron/TapeMeasure/downloads
@moderator, sorry for the big images.
unit conversion...
source code...
download plugin...
Thanks Steven,
Much appreciated!!!
Much appreciated!!!
Re: The Measuring Tool Thread
Stephan Woermann seems to have completed his tool
64-bit only version downloadable from here
Description of the tool:
Left mousebutton:
This starts the measure. The next leftclick will begin a new measure at the current position.
Right mousebutton:
Resets the tool, you can then use a new startpoint.
Shift + left mousebutton:
Will add a new point to existing ones.
Middle mousebuton:
Change the mode to angular and shows the angles between the lines.
The next click change back to the distance mode.
The standard snap options can be used to change the snapping modes, also the region size.
what a great contribution. thanks
Gustavo Eggert Boehs
indeed!!
An impressive work. awesome! A serious measuring!
Tnx for this masterpiece! Thank you!!!!!!!!!!!!
stephan's tool looks more polished. thanks for sharing!
