I'm running 7.01 and I'm having the weirdest issue with a simple Instance Shape node..
I've tried freezing the object & setting neutral pose with no luck (there's no animation on the object either)..
I think I'm just missing something very basic, any ideas?
Instance Shape scale issues
- InstanceShapes.JPG (195.34 KiB) Viewed 1137 times
Re: Instance Shape scale issues
Did you by any chance also freeze the transforms??
edit: Didn't look properly at the image.... You already did that.
No clue atm, sorry..
I feel sorry for even asking this question, but what's your Scale on the Particles?
Scale: 1,1,1Leo wrote:I feel sorry for even asking this question, but what's your Scale on the Particles?
Mass: 1
Direction: 0,0,0
Speed: 0
Other shapes such as a bottom-less cube, seem to instance fine with no scaling issues..
Hi, reset your neutral pose, then do freeze scale.
I'm assuming that by reset you meant remove.. Worked! Thanks!!
