K Means Clustering
K-Means Clustering
Partitions a polygon mesh with the k-means method.
In the thread linked below, Constantine shows some applications of that method.
local backup: k-means.rar
author site: http://procedural.tumblr.com / si-community thread
Re: K Means Clustering
Can you rephrase the question please?
Ok. Thinking about it again it is more the case of turning several objects into a unique object conforming to a reference form.
K Means Clustering compound provides unique island indices by which you can filter and move points as if they were a separate object, if you mean it
[rimg=250]http://img59.imageshack.us/img59/9571/30fb5cfd29454a4388e3ac0.png[/rimg]
But unique objects are necessary for export for other packages i think.
Looks very intersting for stone walls, or stone giant creatures and stuff...
good job
good job
Gustavo Eggert Boehs
@bullit: Then script it, polygon island are easy to isolate via the SDK! And by the way, you can't create new objects with ICE
Beep, Beep, back up for a minute This compound can take a solid object, and break it up as though it was modeled separately, is that what I read correctly ?iamVFX wrote:K Means Clustering compound provides unique island indices by which you can filter and move points as if they were a separate object, if you mean it
Not exactly... It breaks up geometry on islands, as if you break object with some sort of shatter tool but within of ice. And by breaks up I mean just gives the unique indices to random polygon clusters (see the screenshot from the first post).Falam wrote:Beep, Beep, back up for a minute This compound can take a solid object, and break it up as though it was modeled separately, is that what I read correctly ?
If you want to break up the geometry by its existing polygon islands, see Guillaume's Polygon Islands Transformation using ICE, it's pretty effin awesome tool for all sorts of procedural animations.
With such power we can make Flintstones movie!gustavoeb wrote:Looks very intersting for stone walls, or stone giant creatures and stuff...
But really not just for stones... The only limit is your imagination.
[rimg=650]http://img202.imageshack.us/img202/9987/b120de02b3c841afb3d6f43.png[/rimg]
very cool!
keep them coming, this kind of stuff should be shown out of the forums more often.
we're not just a particle app people!!
Compound is updated, now you can feed custom array of center points to it
I guess that's not KISS, but partial understanding of the k-means article. What you show here is just a search for closest center from array of centers to each particle. And looks like you can improve this bruteforce search by get rid of the last "Find In array Node"Yes, you can! Everyone can, I continue my K.I.S.S. workflow. And the most funniest part - that formula that you showed me - I don't understand it and I'm not used it
I got 3.3 sec against 5.0 when did this removing on 1k centers.
This is embarrassing You're right, there's no need for second Find in Array node
Hi there,
Trying to reproduce the "Transferring cluster ids to disconnected island polygons" Ice Tree http://img542.imageshack.us/img542/2598/0d727d412162497faefb6bf.png
I get context troubles either connecting the "Cluster To Center Indices" output to the disconnect Islands" input or
to the "3d vector to 4d vector" input.
(Ice tree is on the Dragon polymesh) (but doesn't work either on the pointcloud)
I'm missing something probably obvious here...
A little help ?
A little help ?
Dive into the K Means Clustering compound and replace Get Point ID and Get Point Position nodes to Get Polygon Index and Get Polygon Position respectively
