QuickInsetAuthor: Piotrek Marczak Updated May 2013 (
info) — Rewrite of the original QuickExtrude tool. This tool performs quick modo-like
interactive extrude, bevel and inset operations without showing a property page. Piotrek's
notes from the si-community thread:
Extruding along normal is available only in 2012 SAP
for operations that relies on SI units you drag in component's normal direction,
for other ops (like point skirting ratio/bevel subdivisions) just drag across screen
subdivision highlighting is supported only for level 1 and only catmull-clark
J, L hotkeys change subdivision on extrude K hotkey is for repeating operation on highlighted component/subselection ENTER shows op PPG shift makes operations 10x slower
LMB is extruding, LMB and then RMB - changes inset ratio of extrusion MMB is beveling, , MMB and then RMB - changes bevel subdivisions RMB is insetting tool can also work in supra mode if you hotkey the tool
I've used it to model few production objects and it's pretty useful.
Developed with the
interactive tool SDK. See Piotrek's
video for a quick introduction
local backup: quickextrude_0.2.xsiaddon (June 2013) pmQuickExtrude2012.xsiaddon (older but SI 2012 compatible version) quickextrude_src.rar
Memag
Post
by Memag » 22 Feb 2012, 17:22
origin wrote:no problem
memag, what's the software you used in this video?
It's called
Voidworld (will be renamed to
Nvil). Something like Silo,XSi,Max and bunch of other modeling tools in one (although it has disabled animation and painting modules inside, which would be enabled and polished later on).
You can get it
here for free(download the last update)...it's still in development but has nice toolset.
But, still clunky at the moments.
Voidworld page
Polycount VW thread
CiaranM
Post
by CiaranM » 25 Feb 2012, 03:03
Really awesome work. Thanks for sharing!!!
j3st3r
Post
by j3st3r » 02 Apr 2012, 09:10
Hey,
And how does your "Screen Space Proportional Transform" project progress?
This one is very neat, it'd be nice if you release an addon with your Quick* tools.
origin
Post
by origin » 03 Apr 2012, 21:36
Sorry didn't have free time recently, but I will finish it thats for sure :/
Falam
Post
by Falam » 08 Oct 2012, 02:21
origin wrote:Tool was rewritten few times, so please report bugs...
- Extruding along normal is available only in 2012 SAP
- for operations that relies on SI units you drag in component's normal direction, for other ops (like point skirting ratio/bevel subdivisions) just drag across screen
- subdivision highlighting is supported only for level 1 and only catmull-clark
- J, L hotkeys change subdivision on extrude
- K hotkey is for repeating operation on highlighted component/subselection
- ENTER shows op PPG
- shift makes operations 10x slower
- LMB is extruding, LMB and then RMB - changes inset ratio of extrusion
- MMB is beveling, , MMB and then RMB - changes bevel subdivisions
- RMB is insetting
- tool can also work in supra mode if you hotkey the tool
- I've used it to model few production objects and it's pretty useful
Is this the updated keyboard short-cut list for this tool ? I have a question about the "K" tool, when you say repeating, does that mean I can select a new set of polygons and repeat repetitive tasks on another set, similar to a macro action ?
origin
Post
by origin » 08 Oct 2012, 22:10
Yes as far as i can remember
Falam
Post
by Falam » 09 Oct 2012, 14:39
Sorry, what I meant was a action, similar to Photoshop. If the polygons are the same, I run the macro and all the extrusions and bevels are done automatically.
origin
Post
by origin » 14 May 2013, 22:01
Updated 1st post with small patch (File with comment " LATEST" )
-fixed some bugs with selection, multiple objects and others
-removed selecting feature
-tool now will extrude by clicking anywhere in viewport when component selection is not empty
-repeat op key 'k' will work also after re-launching tool, e.g. if you want to repeat bevel on different set of components
-better visual representation of extrusion axis
pluMmet
- Skype: bigcuberight
Post
by pluMmet » 15 May 2013, 00:26
Great tool. Thanks for keeping it up!
Post
by wireframex » 15 May 2013, 08:04
Thanks for sharing
Nox
Post
by Nox » 10 Aug 2013, 11:51
Great update, selecting feature was annoying, now it works perfectly, thanks!
stevejjd
Post
by stevejjd » 05 Nov 2018, 10:49
How do I assign a hot key to these tools? Thanks
Legends Never Die
Maximus
Post
by Maximus » 06 Nov 2018, 10:48
stevejjd wrote: ↑05 Nov 2018, 10:49
file > keyboard mapping > on the left column find "custom script commands" then on the right column find "pmQuickExtrude" and drag and drop it to any hotkey you want.
stevejjd
Post
by stevejjd » 06 Nov 2018, 22:46
Maximus wrote: ↑06 Nov 2018, 10:48
Thank you so much ~ I found it
I wont let Softimage die - I'm gonna learn it. I love it already. Much better than Max and Maya. I hope someone from Autodesk just steels XSI and leaks it to the world.....that shit should be open source.
Legends Never Die
Users browsing this forum: No registered users and 71 guests
