OpenVDB to Softimage
OpenVDB ICEAuthor: Oleg Bliznuk
This is a Softimage ICE integration of the OpenVDB suite, Dreamworks Animation's volumetrics toolset which has been built around a new data structure for efficient storage and manipulation of big volumes. See openvdb_dreamworks.pdf for slides of a OpenVDB feature presentation.
Oleg Bliznuk, author of Exocortex's Implosia FX and Explosia FX has created this ICE adapter. His fluid simulator »Explosia FX« (free as a noncommercial version) can be used to create VDB files. OpenVDB ICE covers the essential features of the OpenVDB suite:
For feedback and questions, visit the si-community thread. There's also some info there on how to interoperate with emFluid. Here is a demo video by the author and another video from the thread, created by Rob Chapman using only OpenVDB ICE nodes and rendered using the included openVDB arnold shaders. Requirements: Microsoft Visual C++ 2012 Redistributable Package (x64)
amr_helmy
Re: OpenVDB to Softimage
Post by amr_helmy » 03 Jan 2014, 18:24
Mr.Core wrote:well, seems like something is messed up, because i see warnings about conflicting versions. To be sure, delete all openvdb stuff ( workgroups with ice nodes\arnold shaders from the sitoa folder ). then, 1) redownload archive 2) unpack and connect the VDB2SI_WG folder in the plugin manager 3) unpack the "extractToSITOAdir" into the C:\Users\username\Autodesk\Softimage_XXX\Addons\SItoA\Application\Plugins\bin\nt-x86-64 4) restart XSI
also you need to have installed vs2012 redistributable
First of all, mental ray shaders ( mi ) must work even if the arnolds package is not found
hi i did what u said
and it give me that error below
by the way .. in a new scene the shader doesnt appear in render tree
but the scene with the file render with arnold and 3 shader appear in ice tree.. black body is not there
Rork
Post by Rork » 03 Jan 2014, 18:27
you might have more response posting in the Arnold mailinglist....
Mr.Core
Skype: giga-core
Post by Mr.Core » 03 Jan 2014, 18:45
try to disconnect the vdb workgroup, then connect it again ( this should set loading order to load arnold plugin dir first then vdb stuff ), or wiat till I will post an update of shaders without that piece of intel bs ( i mean tbb.dll )
Tekano
Post by Tekano » 04 Jan 2014, 15:39
works ok for me! :D
thank you Oleg, what is not clear here is that you have implemented a whole load of existing VDB code & functionality inside ICE compounds with this - so the cloud rendered here is completely procedurally generated with ICE and VDB nodes. no houdini involved ;) fantastic stuff, it is tremendously useful for some of us Softimagers to remain in touch with latest industry developments. it seems openVDB is more popular and succesful than Field3D ?
Mr.Core
Skype: giga-core
Post by Mr.Core » 05 Jan 2014, 22:42
You are welcome, Rob :) I'd like to get some feedback and wishes on future implementation since it is not always clear how to better implement something here and there. I think openvdb has a far better spreading because of it's wide set of tools for volumetric processing, while field3d is only format by itself ( if i am not mistaken ). And i have feeling that openvdb has more agressive promotion :-)
caledonian_tartan
Post by caledonian_tartan » 06 Jan 2014, 12:06
this is amazing!
played around with it a bit.
i'd love to see a connection to emFluid. (is that possible?)
or more examples for ICE only situations.
unfortunately i don't have anything to show yet. i'll go on and try again.
thank you very much Mr.Core
SI 2015 @ WIN7-64
Mr.Core
Skype: giga-core
Post by Mr.Core » 06 Jan 2014, 16:49
Nothing special have to be done - emfluid just need to export in .vdb format and thats enough :)
caledonian_tartan
Post by caledonian_tartan » 06 Jan 2014, 17:06
...Nothing special have to be done...
i used "VDB Voxelize Particles" which worked so far.
but as this only translates "point-/-size/-velocity/-position", no voxelgrid/velocitygrid... i didn't get a cool look at all.
so guess caching to .vdb is needed...(?)
EDIT:
how do i do that?
SI 2015 @ WIN7-64
Mr.Core
Skype: giga-core
Post by Mr.Core » 06 Jan 2014, 17:39
i dont have emfluid, but suppose we have access to raw voxel grid values, then you can build something like this:
Mr.Core
Skype: giga-core
Post by Mr.Core » 06 Jan 2014, 17:42
however, I heard somewhere emfluid has native exporting to vdb, so ask Eric for this to make sure
caledonian_tartan
Post by caledonian_tartan » 06 Jan 2014, 21:55
thanks Mr.Core
i followed your setup, but had to change some stuff.
it renders quite ok, but there's something wrong with the voxelsize.
not shure about it.
SI 2015 @ WIN7-64
Tekano
Post by Tekano » 07 Jan 2014, 00:53
thats an emfluid pointcloud Tartan? that so will not work that way, but good effort :) you could go down that path andemit some particles and advect them through your emfluid sim.. but the easy way would be to do like Oleg says and export the fluid grid cells as a vdb file - which version of emfluid are you on? the latest versions or so support this. I know this because we tested the exported vdb sequence in houdini.
now we do not have to. :-bd
Tekano
Post by Tekano » 07 Jan 2014, 01:39
Mr.Core wrote:You are welcome, Rob :) I'd like to get some feedback and wishes on future implementation since it is not always clear how to better implement something here and there. I think openvdb has a far better spreading because of it's wide set of tools for volumetric processing, while field3d is only format by itself ( if i am not mistaken ). And i have feeling that openvdb has more agressive promotion :-)
excellent, well a list or an idea of which bits of VDB code you have implemented into ice nodes and what are there compound names.. or have you converted the entire cookbook!? going inside the compounds you made like solidify level set is actually change grid class. and then I am trying to go to the VDB docs to find where this is detailed but not having much luck to find the correct section or parts of the VDB docs so a wish to make it easier to translate some correlation between the library code functions names in the docs and the ICE compounds.. somehow? eg which compounds are or where are the VDB iterators, or the Tools
Utilities and Tools
OpenVDB provides utility functions and classes for the manipulation of grids and the data they hold. Tools such as those found in GridOperators.h compute vector quantities from scalar data or vice-versa. Other tools perform filtering (Filter.h and LevelSetFilter.h) and interpolation (Interpolation.h) as well as sampling (GridTransformer.h), compositing and constructive solid geometry (Composite.h), and other transformations (ValueTransformer.h). OpenVDB also supports advanced finite difference computations through a variety of local support stencils (Stencils.h).
a simple matter to do some more experimenting & reading on whats there - and I see there is a lot converted already , its a heck of a lot of stuff! :D
**edit** and a request - I do not see these below:taken from http://www.openvdb.org/download/openvdb_toolset.pdf I wonder if even VDB guys have done all these yet! :D
Gradient
tools::gradient
Mean curvature
tools::meanCurvature
Closest-point transform
tools::cpt
Divergence
tools::divergence
Laplacian
tools::laplacian
Buoyant density in an incompressible
fluid simulation
Magnitude
tools::magnitude
Curl
tools::curl
because in theory this should be way faster to do large scale neighbor lookups using vdb nodes than nearest neighbours in ICE itself?!
caledonian_tartan
Post by caledonian_tartan » 07 Jan 2014, 10:06
...export the fluid grid cells as a vdb file...
i'm using emFluid4. haven't yet found out how to export vdb...
SI 2015 @ WIN7-64
caledonian_tartan
Post by caledonian_tartan » 07 Jan 2014, 13:09
ok. looks like this does the trick to match voxel grids and data content of emFluid and VDB.
still some issues.
e.g. i build the colorGrid inside emFluid as it does not exist like so. looking up with closest location decreases performance massivly...
also i expected a little bit more details with a cell size of 0.2...
Tekano
Post by Tekano » 07 Jan 2014, 16:43
I do believe you are turning the emfluid visualizer particles to VDB rather than the actual fluid grid.
version 4.0 you can cache the grid to Bafl format. for VDB it is the same way just rename to vdb in the export - but it could be a later version than you currently have
