FXTree Tracking to null
The compound internally builds a camera frustum and translates fxtree tracking data to 3d data.
Two things you should know before using:
- be sure to align camera and interest Y position before applying the compound. (that's because frustum rotation is not being calculated yet)
- change the image resolution inside the compound to fit your dimensions. (didn't find a way of retrieving image resolution right inside the ice tree)
...being using this one a lot in shots involving simple 2d tracking (no rotation, or hand keyed rotations) for object replacements, prop attachments, etc..
compound will be stored under Tools > Tracking.
enjoy!
- Apply 2d Tracking.rar
- Apply 2d tracking ice compound
- (5.06 KiB) Downloaded 1137 times
Re: FXTree Tracking to null
This is great Fabricio, thanks a lot! Is there anyway of using all 4 trackers per node in Fxtree? Example: in one node there is 4 trackers, you track then make a nul (4 of them) and apply your compound and it consider all 4 trackers to all 4 nulls in scene.
Disregard previous post..i can make template so all is fine and kinky...thanks a lot once again.
a
a
