I'm experimenting with elastic and fluid like deformation (simulated).
It's not yet well documented, but I think it's easy to understand the nodes.
Feel free to make better versions and share here!
Usage: put flubber_initialise in the modeling stack, put flubber_simulation in a simulation stack of a mesh object, add deforming mesh to flubber_simulation.
Cheers, Wim
flubber
Flubber
A nice wobbly effect for meshes — demo video . From the si-community thread:
I'm experimenting with elastic and fluid like deformation (simulated). It's not yet well documented, but I think it's easy to understand the nodes. Feel free to make better versions and share here!
Usage: put flubber_initialise in the modeling stack, put flubber_simulation in a simulation stack of a mesh object, add deforming mesh to flubber_simulation. Cheers, Wim
local backup: flubber_initialise.xsicompound flubber_simulation.xsicompound
author site: http://www.mantelli.be / si-community thread
Re: flubber
Looking super great jello!
Well done and thanks for sharing
Portfolio / Blog
http://www.nuverian.net
Re: flubber
Looks great, BUT is it also possible to have the flubber collide with the cube?
Thomas
Thomas
Re: flubber
Wow, awesome!!!!!
Re: flubber
For the moment it is not real collision, I look for the location, if the point is in a certain distance I get the velocity of that location and add it to the velocity of the point.
It shouldn't be to difficult to do real collision, just test if it's inside cube, then move to closest position on the cube each frame, the spring effect should do the rest.
I wanted an effect of something floating- cutting through the water, so I didn't realy wanted to push the points away.
It's a surprisingly simple icetree, like I said feel free to make new versions and post it here, if I have time I will make a clean version with some options.
Cheers, Wim
Cheers, Wim
Users browsing this forum: Bing [Bot] and 47 guests
