Hi.
New to Linux and trying to install and run Softimage 2015 ... Got it installed but slightly stuck on how to actually run the software (slightly embarassing I know !!!!)
Anyway, when I run XSI from inside the /bin/ folder, I get this error :
/usr/Softimage/Softimage_2015/Application/bin/XSI.bin: symbol lookup error: /usr/lib64/libXext.so.6: undefined symbol: _XGetRequest
Any one know what might be the problem ? Really want to keep using XSI rather than migrate to Houdini !
Eugene
Softimage 2015 - Fedora 21 - Unable to run
- eugenerockstar
Re: Softimage 2015 - Fedora 21 - Unable to run
Hi, searched for the last bit of your error message,
and found this from here:
MailingList -- Soft 2014 in Linux is "always-on-top"?
xsisupport.com -- Running Softimage on other distros like Ubuntu, Kubuntu, Pardus, and Gentoo
(Perhaps Stephen could add the previous to that linux install help page?)
www.getsetdata.com -- FINALLY!! Softimage running on Ubuntu!
Cheers & Let us know how it goes,
Sylvain Lebeau wrote: Hi thomas and Christoph....
i am struggling to make Softimage work in Fedora 18. I remember seeing some errors in the install log too. But i dont have it underhands right now.
here's the error i get when i try to launch XSI
if any of you could help me out, it would be greatly appreciated.
/usr/Softimage/Softimage_2014_SP2/Application/bin/XSI.bin: symbol lookup error: /usr/lib64/libXext.so.6: undefined symbol: _XGetRequest
thanks!
sly
Each flavor seem to have particular needs, but this also seemed to have helped others:Christoph Muetze wrote: Hi Sylvain,
Fortunately the solution to your problem is fairly simple:
mv
/usr/Softimage/Softimage_2014_SP2/Application/mainwin/mw/lib-amd64_linux/X11/libX11.so.6
/usr/Softimage/Softimage_2014_SP2/Application/mainwin/mw/lib-amd64_linux/X11/~libX11.so.6
Cheers,
Chris
- eugenerockstar
Thanks ... that worked a bit.
I'm now getting ...
Abort (core dumped)
when I start. I've read through that post, but can't seem to find a solution.
Eugene
I'm now getting ...
Abort (core dumped)
Eugene
Perhaps this? from here:
XSIList -- Fedora 14 "Abort (core dumped)"
Stefan Andersson wrote:Hi all,
Trying to get Softimage to run on my macbook pro using fedora 14. we
install all of our machines at the office the same way, but it doesn't
seem to work on my laptop.
Here is the strace of XSI.bin
anyone has any idea on whats going on?
regards
stefan
Thomas Volkmann wrote:Check your /etc/hosts file. I was getting that error when installing on FC15 and it turned out that it was somehow wrong formated (my actual hostname didn't show up there).
cheers,
Thomas
(always a little thing isn't it )Stefan Andersson wrote: Thanks Tomas! That was it!
regards
stefan
