Interesting, the Autodesk rep told me R2 was the same as 2015 SP2 other than the FBX libraries being updated(this alone made it a worthwhile update for me). There's probably other unspecified bug fixing and suchlike.nospitters wrote: ↑20 Oct 2017, 16:39 in my case installing the r2 solved previous immediate crashes on rendering in xsi2015sp2 also with the win10 update...so there must be some differences...
Sycles 2.1.3
...but i think bennyhase is also right, because on my laptop there is xs2015(no sp1, sp2, r2) and there is also rendering fine(but no gpu mode, because no nvidua card...)
very strange...
very strange...
The Soulcage Department
http://www.soulcage-department.de
It's great that all works correctly on most users. About using *.cubins from Blender distibutive: as I understand these files should be generated with the same compiler (or driver, or system version, or something similar) as other cycles libraries. So, files from Blender are not compatible with Sycles in most cases. Jonmoore, try this link: https://mega.nz/#!Uw5V3Lja!m8wf_Ra1u0xZ ... 1OGDPDISrs
May be files from this archive will works. In any case, I will add additional cuda architectures in next update release (whenever it will be).
Thanks for trying but not only did the 1080 Ti not work with those .cubins but the 980 Ti stopped working too.Shekn wrote: ↑20 Oct 2017, 20:18 It's great that all works correctly on most users. About using *.cubins from Blender distibutive: as I understand these files should be generated with the same compiler (or driver, or system version, or something similar) as other cycles libraries. So, files from Blender are not compatible with Sycles in most cases. Jonmoore, try this link: https://mega.nz/#!Uw5V3Lja!m8wf_Ra1u0xZ ... 1OGDPDISrs
All good, I really appreciate your efforts to find a solution. Take your time with the next version but feel free to throw test GPU files my way for testing (seeing as you don't have a multi GPU setup to test with at your end).
A fully functional Cycles inside XSI will be a huge asset to the community and you're very close to delivering that achievement.
A few notes ::
If you get black renders, it probably has to do with default light intensities.
In the light's "cycEmission" shader under any light,the default is 5, and the slider soft-limit is 50,
and I had to bump it to 500 to see them, or 1000 to have them bright enough.
Point, Area, and Sun lights all work, but I somehow couldnt get the the skyLight to work.
But applying the "cycEmission" shader to a regular poly sphere worked, and acts as a dome light.
Here is a sample scene with a few things applied,
and a working SunSky setup and includes a basic interior for testing...
SyclesFirstTry_v15.scn
For other SI versions, here are steps taken for the procedural
sky to work.
When you apply the cySkyTexture to a sphere, it looks like this ::
So from there you can delete the bottom half polys,
then select all top polys and scale them down in Y
up-to the thin band where all the sky info lives.
This is the dome seen from the bottom ::
If you scale the polys down too much, you would see some pinching at the center ::
Just right ::
Then you can scale UP in Y the *OBJECT* to more or less a dome,
giving something like this ::
Other Pics ::
____________
One rather important thing I could'nt figure-out, is how to get the objects UV's from XSI.
The texture used was applied using the spherical projection in the "cycImageTexture" node, (there is also planar, box, etc ....)
but **is there a way to use the object's actual UV's ? **
_____________
On a side note
The shown interior pic at that res and grain level took 20 min on my CPU.
Used the CPU mode because my GPU is a lower mid-range laptop Nvidia 675MX,
and was about half the speed of CPU mode so that pic with my GPU would have been 40 minutes.
A GTX1080 is about 5 times faster than my gpu (so 5x faster than my 40 minutes in gpu mode = 8 min).
And extrapolating that to 1080p res, would be just about ~7 hours on my CPU (or ~14 hours on my GPU),
and would be some ~3 hours on a GTX1080.
Letting it go twice as long, there would obviously be less noise, but not that much, where the denoiser becomes important.
Anyhoo, voilà!
sky to work.
Just right ::
Other Pics ::
____________
_____________
On a side note
Anyhoo, voilà!
1. About using skyTexture node. Look at tutorial 3 in HowTo manual. Shortly speaking, you should add background light source, add to it material the node skyTexture and set the sun light to be a child of this background light. To see the texture on rendered image turn off transparent checkbox on Background group of the render parameters.
2. About uv-coordinates. Now Sycles use only one uv-property of the object. If the mesh contains CyclesMesh property, then UV Index value determines the index of used uv-property of the mesh. If there is no CyclesMesh property on the object, then Sycles takes the first uv-property. But on the next update I will add the export of all uv-coordinates to vector attributes and any of them can be available throw the node cycAttribute. Now you can select uv-coordinates of the object by using the node TextureCoordinates. UV-output is actual uv-coordinates of the object, other outputs (Generated, Normal, Object, etc) are automatically generated coordinates. So, you should connect UV-output of this node to Vector-input of the node ImageTexture. Projection of the ImageTexture should be always be Flat.
Right! the how-to manual!
I got the addon from the direct link, and didn't spot a doc in the extracted addon files, but found it made obvious on your site.
And it is indeed very thorough and straight forward, and describes a TON of features I wasn't even aware of lol.
( direct link in case anyone else missed it :: Sycles HowTo 05-10-2017 Eng.pdf )
Even without the doc, I found everything to be like very easy.
I also suspect using the skylight would be somewhat faster if not emitted from an actual mesh as a main light source
(as is typically the case)
Something else I wanted to ask ::
there seems to be a positional (or focal?) discrepancy between the Sycles camera and the XSI camera, also noticable in the region.
I'm sure you are aware of it, but do you think it is something that can be somehow solved?
For a variety of reasons, if not just for accurate cam positioning in general, but perhaps mostly, since motionblur is'nt supported
this issue prevents generating motion vectors pass (or any other pass) in MR
( even if MB was supported, motion vector pass allows for very quick results )
In the same vein, would 3d motion blur (or motion vector pass?) be a possibility at some point? or is it like a hard limitation?
In any event, kudos on this already truly amazing integration!!
About different camera frames from Cycles and Softimage. I tried to solve it, but without success. And I don't know why this difference appears. Frames coincide with camera aspect = 1.
I will try to implement motion blur. I believe that it is possible, but don't know when this will be done.
Ok, in the mean time, I just saw a "PASS_MOTION" aov, so peraps that would that be an avenue for MB until then?
(will try it)
thanks again!
(will try it)
thanks again!
Hi Shekn,
Just to let you know, I actually could'nt quite get the PassMotion AOV to work,
it seems to render just black while other AOV's work fine.
Perhaps for the same reason motion blur itself is not working?
(or perhaps did I miss something else?)
So I went back to considering what prevented using other renders including MR for motion vectors... (or for other things)
For the camera FOV differences, I can see how it may have been tricky,
I was able to visually match diffences between XSI FOV and what is displayed by Sycles,
and the narrower the Field of View, the less the difference between XSI and Sycles...
the wider XSI's FOV, the more the Sycles FOV vired off
but the difference isn't either constant or linear.
So I drawn a big as possible region (fullscreen), and visually matched XSI's FOV to what Sycles was interpreting, ...
... and plotted the results using Fcurves on a null going from 0 to 300.
The red Fcurve is the curve that represents XSI cam FOV, it's linear and ends at 300 in Y, and 300 in X
and the selected curved curve represents the FOV values that Sycles interprets at each 30 degree incement
These are the plotted values...
XSIValue = SyclesValue (Normalized Percentage (or ratio) of XSIValue)
0=0 (1)
10 = 9.999 (0.999/1)
30 = 29.525 (0.984/1)
60 = 56.610 (0.944/1)
90 = 80.193 (0.891/1)
120 = 99.788 (0.831/1)
150 = 116.468 (0.776/1)
180 = 130.435 (0.724/1)
210 = 142.767 (0.680/1)
240 = 153.799 (0.641/1)
270 = 163.944 (0.60/1)
300 = 173.661 (0.578/1)
Here are the same curves but normalized (going to max 1 instead of 300)
with the extra (blue) curves representing the Sycles FOV ratio of XSI's FOV ,
and an inverse of that curve around 1
And with that inversed ratio curve profile ... brings the next question ::
you mentionned that camera FOV is now 1:1 ... so could it -not- be 1:1?
or can the value sent to Cycles be processed by a curve function?
I ... as well as others using Sycles I'm sure, would certainly hope so
Here is the process represented by an Ice tree , along with the compound (**and the curve inside the compound**)
XSI to Sycles FOV.xsicompound
In any event, thanks & let your thoughts!
0=0 (1)
FXDude, thank you for your research. I will try to fix the difference between XSI and Cycles cameras. Motion pass is empty in Sycles render result because at present time no data transfers to render for rendering this pass. This pass is not working. At all.
No prob, and awesome! (for camera fidelity )
Thanks, that's what I thought, it seems to also be an issue in other Cycles integrations as well for the moment..
I don´t know the parameters you need to set up a camera in Cycles, but here is a part i used in Octane.
float aspect = static_cast< float >( camera.GetParameterValue( L"aspect" ) );
CVector3 si_up, si_dir, p, t;
CTransformation trans = camera.GetKinematics().GetGlobal().GetTransform( evalTime );
CMatrix4 mat = trans.GetMatrix4();
// UpVector
si_up.PutX( mat.GetValue( 1, 0 ) );
si_up.PutY( mat.GetValue( 1, 1 ) );
si_up.PutZ( mat.GetValue( 1, 2 ) );
si_up.NormalizeInPlace();
// Direction
si_dir.PutX( mat.GetValue( 2, 0 ) );
si_dir.PutY( mat.GetValue( 2, 1 ) );
si_dir.PutZ( mat.GetValue( 2, 2 ) );
si_dir.NormalizeInPlace();
// PositionVector
p.PutX( trans.GetPosX() );
p.PutY( trans.GetPosY() );
p.PutZ( trans.GetPosZ() );
// TargetVector
CVector3 look_tmp;
look_tmp.Scale( static_cast< double >( camera.GetParameterValue( L"interestdist", evalTime ) ), si_dir );
t.Sub( p, look_tmp );
// FOV
float fov = static_cast< float >( camera.GetParameterValue( L"fov", evalTime ) );
if( camera.GetParameterValue( L"fovtype", evalTime ) == 0 )
fov = float( RadiansToDegrees( 2 * atan( tan( DegreesToRadians( fovTmp ) / 2.0 ) * aspect ) ) );
Thank you, Face. Your code is really helped to fix the difference between XSI and Cycles cameras. The final code:
float camAspect = camObj.GetParameterValue("aspect", evalTime);
float fov = camera_obj.GetParameterValue("fov", evalTime);
bool isHorizontal = camera_obj.GetParameterValue("fovtype", evalTime) == 1;
if ((!isHorizontal && camAspect >= 1) || (isHorizontal && camAspect <= 1))
fovGrad = fov;
else
if (camAspect <= 1)
fovGrad = RAD2DEGF(2 * atan(tan(DEG2RADF(fov) / 2.0) * camAspect));
else
fovGrad = RAD2DEGF(2 * atan(tan(DEG2RADF(fov) / 2.0) / camAspect));
No problem, if you need also an orthographic camera, it will be calculated with:
if( camera.GetParameterValue( L"proj" ) == 0 ) {
// CVector p/t from the above code segment
CVector3 tmp;
tmp.Sub( p, t );
float fact = ( float )camera.GetParameterValue( L"orthoheight", evalTime ) * aspect;
fov = float( RadiansToDegrees( atan( fact / ( tmp.GetLength() * 2 ) ) ) * 2 );
Hi, just to say :: Thanks for the valuable insight face!
