Dynamic loading texture
- Skype: nguyenvuducthuy
Hi, i want to animate a texture by loading its from an folder, for example in frame 0 i load texture "A" and in frame 10 i load texture "B" and so on ... Is there a way to do it in softimage?
Re: Dynamic loading texture
shure!
import as image sequence, drive time source.
check out this post:
http://www.si-community.com/community/v ... =15&t=2786
SI 2015 @ WIN7-64
Thanks for the answer,
But it's only work with particle in that case source time can be drive by ice attribute
i found the way to do it simple create a script OP
filePath = In_UpdateContext.filePath.Value
obj = In_UpdateContext.obj.Value
fileName = In_UpdateContext.num.Value
file = filePath + "\\" + obj +"_"+ str(fileName).zfill(2) + ".png"
sel = Application.ActiveSceneRoot.findChild(obj)
exportClip = sel.Material.CurrentImageClip
exportSource = exportClip.Source
exportSource.Parameters("FileName").Value = file
