Daes exist a plug in that visualize laser scan point cloud?
I'm looking for, some one know if exist? Thank you!
Re: Daes exist a plug in that visualize laser scan point cloud?
Not entirely sure what you're looking for, but most laser scan equipment comes with software to load the pointcloud and export it to formats 3D apps understand.
I'm pretty sure Softimage + the Mootzoid tools can import some of the data exported.
Hope this makes sense.
thank you, i'll look immediately. Thank again!
- Daniel Brassard
An alternative would be to load the point cloud in MeshLab or Meshmixer and save the resulting mesh as an .obj file then load the file in Softimage. You can use any of these programs to create stl files and analyse the mesh to get them ready for 3D printing as well.
http://www.meshlab.net/
http://www.meshmixer.com/
thank i'll try it too, i have to edit laserscan from racetrack to recreate buildings in the EXACT position. So if the the mesh is in some way good, is all right .
Thank for you answer!
"Cloud Compare" (http://www.danielgm.net/cc/) does also help a lot for converting to different formats. Houdini has some LIDAR functionality built in by the way...
cheers,
oli
cheers,
oli
http://www.pixelpanic.de
double thank you again!!!!!!!!!!!!
